SnowDrifter Posted June 25, 2012 Report Share Posted June 25, 2012 Yes ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 25, 2012 Report Share Posted June 25, 2012 Mmmm Hmmm.... cool,... good damn luck bud.......... really...... smack at you in the am....... and hope its nuttin..... go to school bro....... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
AA98hoe Posted June 25, 2012 Report Share Posted June 25, 2012 im curious now when they tested it..did they actually hook it up to subs or just dd1.. your power source should be fine for quick testing.. just power it up run a signal into it and touch gain knob.. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
Pro7 Posted June 25, 2012 Report Share Posted June 25, 2012 If you only hook up the dd1 and not the subs there should be much less current draw since the dd1 should be of higher impedance than the subs which equals less power obviously I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before Link to comment Share on other sites More sharing options...
OrionStang Posted June 25, 2012 Author Report Share Posted June 25, 2012 im curious now when they tested it..did they actually hook it up to subs or just dd1.. your power source should be fine for quick testing.. just power it up run a signal into it and touch gain knob.. Well the lpf and ss were set for music. I know thats the wrong way to use the dd-1. Seem's a little shady, but who knows. If you only hook up the dd1 and not the subs there should be much less current draw since the dd1 should be of higher impedance than the subs which equals less power obviously Thats what I was thinking. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
CJ18 Posted June 25, 2012 Report Share Posted June 25, 2012 You should be just fine testing on one battery, I know rusty uses anas rex to test amps all the time with 1 battery. It could have been something with his settings on his head unit or if he had a signal booster(cant think of the correct term) inline before the amp. Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 25, 2012 Report Share Posted June 25, 2012 You should be just fine testing on one battery, I know rusty uses anas rex to test amps all the time with 1 battery. It could have been something with his settings on his head unit or if he had a signal booster(cant think of the correct term) inline before the amp. Thanks bro,... as always,.. the man Cj in for it for ALL the member here..... thanks again dude... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
CJ18 Posted June 25, 2012 Report Share Posted June 25, 2012 Another possibility could be a defective dd1. I had an issue with mine where on the 1khz tones while trying to set my 4 channels, I would get an immediate distortion light. Not sure what caused this malfunction, but I sent it back and it was fixed. Link to comment Share on other sites More sharing options...
deathcards Posted June 25, 2012 Report Share Posted June 25, 2012 check the battery in the dd-1? i mean try a different 9v battery skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
Real96SS Posted June 25, 2012 Report Share Posted June 25, 2012 I dont know if I read wrong or what but did you say they had the speakers hooked up while setting the gain? Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/ Link to comment Share on other sites More sharing options...
