I used Torres to design the box and it told me physical port length 12in so thats how long the port wall is behind the double baffle. What I put in for port was 20in
It's more or less impossible to have a 20" port if your depth is only 23", and that's probably why torres gave you a weird dimension for physical port length. But let me get this straight. You just put in a 12" piece, no L or anything? You didn't stop and think "How do I get a 20 inch port from 12 inches plus 1.5 inch of baffle?"? But in any case, I don't see how this would cause port noise. x2 on pics
i un mine at 0 and -3, but on you setup youll def need -10
And why do you say that?
my is like that as i run a factory hu that drops bass off as the volume goes up, so as to have any bass beyond 2/5 up thats what is requires (if i turn hu to +3bass i clip at 17,18 and 19 out of 50 but then it stop clipping until 42-43) with flat eq i get no clipping until 42-43.
Sharp edges can cause it.
Give pics
...The port not only pushes air out, but takes air in also. So if the port is too small there isnt enough room to do both quietly.
Yes but, what?
And I cant do a hairtrick.
Can you post the Torres screenshot that you used to build that box that box?
Im doin this from my phone so heres what I got
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
2.25 opening between port and i think its net volume is with everything removed don't remember correctly been busy
i think your port noise maybe caused by too small gap between box volume and port
edit fixed some grammar
Edited by deathcards
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
But I think he said above he changed the port wall on his own and now has 8.75" at the port inside the box.
OP - can you post up a sketch with dimensions of what you actually built??
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
o srry trying to help but i think i maybe making it more difficult lol
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
