Escalade EXT (4)Rockford T2 12's (UPDATE 12/3/12: Complete! Video & Pics up)
Check for woofers wired out if phase. It's an easy mistake to make and will.cause the same amount of voltage drop as normal.
Also make sure the amps are set accordingly. Clipping will draw more current.
On note of loudness, open the tailgate and see how it sounds. If louder open, it's not sealed off well enough
Each pair of subs reads 2 ohms at the box terminals.
Checking resistance won't tell you out of phase or not. Do a simple pop test, use a small 9v-12v battery and put positive to + and negative to - if both woofers push out on each side you're polarity is correct. If one pushes out and one sucks in that would probably explain your problem
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
what is the alternator rated at idle? and i would have gone with 3 d3100 for the power youre running
I think the alt is rated at 240 idle. We clamped it and it's putting down like 110 idle, 250 full tilt. We are sending it back to mechman tomorrow. We tried running one amp and 2 T2's off it, with the gain all the way down on that one amp, 10/62 on the radio (pioneer premier test radio), and the amp saw 9V and shut down. We checked all grounds and wired it according to a schematic given to us by our rockford rep. (I didn't personally wire the grounds up). Everything is Rockford 1/0 single run to the cap, buss bars in the back, all soldered terminals, everything is rock solid. This just isn't making sense. The customer is going to buy 2 more xs dc3100s :morepower1: ! And if this alternator passes the test bench from mechman, I just don't know. We are ordering a dual alt bracked and using the factory alt for it's purpose, and the 370 (self exciting) for it's purpose. I really think the alternator is what's causing the problem. As I said, it wouldnt even push 1 2500 with the gain at 1. And I mean the subs were barely moving.
The 370A for those vehicles they say will do around 200 flat at idle. Even if it's only doing 110 at idle it shouldn't drop to 9v at not even 1/4 tilt, one amp. You have a problem somewhere else would be my guess. Also, is the Stinger volt meter hooked up at the amp or the batteries?
The stinger meter is wired into the BCM. It's after the batteries, but before the amps.
Like someone posted earlier if you guys had the alternator hooked up in the OEM spot then it is being controlled by the PCM. If its not in the OEM spot then I think your problem lies somewhere in the wiring or with that Capacitor. Start in the front and work your way rear. Good luck
The Alternator was wired through the factory system via one xs d3400 and the second battery was run straight from the positive post on the Alt.
We removed the Mechman alt and sent it in. It won't work with the vehicle's computer, basically the computer limits the alternator's internal regulator to 200A. We are going to run a dual alt setup with the factory alt and another aftermarket.
electrical kinks ever get worked out?
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Whats up guys? Sorry about the wait on this build. We hit a few problems and the customer couldn't meet his deadline (he drives a truck). But The truck is all done now! She's in the break in phase and is really impressing everyone so far! It never drops below 13v and it'll play loud and hard all day long. We still have the truck for 2 weeks so more vids and pics are on the way. As far as the build itself, she's done.
For the break in, she's turned down a little bit.
T2500's (gain ~5/11)
T600-4 (gain ~4/11)
My coworker attempted to use his dd-1 and cc-1 on the truck, but he said it showed the radio clipping at 40/40 (audible distortion at this level). We were able to get a better sound by tuning by ear, surprisingly. Nothing against you Steve, Just don't think my buddy quite used the dd-1 right. Here are the final stats, pics, and a video.
FINAL STATS:
Electrical - - Dual alts, Mechman (370A) and Factory alternator (160A)
-(2) XS Power D2400's up front, (2) XS Power D3100's in back.
-Rockford Fosgate 10 Farad Hybrid cap.
-Rockford 1/0 Cable for all runs (alt to battery, big 3, grounds etc) (All terminals / connections soldered)
Head Unit - Clarion NX 501
Amplifiers - 2 RF T2500-bdcp's strapped. (Sub stage) Birthed 3450w and 3,050w.
1 RF T600-4 (Front and Rear stage)
Speaker stage - 2 sets of Rockford Fosgate T1 6.5" components (1 in front, 1 in rear doors)
Subwoofers - 4 Rockford Fosgate T2 12"s
Box - Sealed, ~8 ft^3, 1" MDF, split chambers, heavily reinforced with Fiberglass.
Misc, - Viper Smartstart VSS5000
Stinger Voltage Meter
LED light strips (4)
Mechman Dual Alt. Bracket
missing the a video in that last post.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I know this doesn't look like much on the camera, but trust me, it's hitting hard as hell in there. Sealed boxes won't flex as much, but are brutal on higher notes. It'll play low also, down to 25hz and below, it still beats like hell.
We still need to know what the electrical problem was in case some else runs into the same issue
  • Who's Online   0 Members, 0 Anonymous, 1704 Guests (See full list)
