how much power do you give your mids
barney91
So you guys that run pro audio mids and highs how much power do you feed them, do you give them there full rms rateing? For example, I've seen a lot of peolpe run 2 or 3 mids per door, and I was woundering if they power them 100%
I only ask because I've been thinking of trying out some pro audio mids and highs, I saw rockford has 10" mids and they have a 350rms rateing. 350watts to a single speaker seems like a little to much. Would they still sound loud if I was gave them 150rms?
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
I power mine to the fullest. RF is a good company, so if it says it can take 350, it should take 350
And yes, they should sound loud on 150 watts. But then there is the question of why you would get a speaker than can handle 350 watts only to give it less than half that?
true about powering them half there rateing but what rf amp will push out 350 at 4ohms. I was thinking of using there pbr300 to power one 150$ to power a single speaker does seem a little high
Alpine 9884
The Epicenter
2x RF T10001bd
Big 3
Smd DD-1
My aq mids are rated at 100w and Im putting 90 to each and they sound great
Used to have a loud truck
I'm over powering my mids at full tilt and aslong as you turn your hpf up you can overpower to an extent. They get warm from about 30 min of full tilt screaming
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
i have a sax200.4 to 4 neopro 8s.. they are gettin more then rated power haha IMO head room on mids is a good thing
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I'm pretty sure i am getting close to 200w channel running at 2 ohm's and have the gain set conservatively on just the 2 way comps i am using.
Door preparation is key to any good sounding doors.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have a RF 1000-4Ad on my Beymas birth sheet is 350+ x 4 and an Old skool mtx thunder 4202 on my Mb quart tweets which is rated at 70x2 @ 4 ohms so just a tad over 1500 watts ....beymas are rated at 150 rms 300 AES power and440 program power so definitely receiving rated
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
even on cheap pyle mids i have, 20 bucks a pop, i give them 100rms and they handle it easily.
edit: 100 per. it is a 4.125
I'm in the neighborhood of around 800 w RMS with my Sound Quality front stage ...
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
