SnowDrifter Posted April 17, 2013 Author Report Share Posted April 17, 2013 well now that i research a little they seem to actually be for screws... but i was always told to use them for bending wire lmao iono I think the ones at the top on either side are for bending wire. They do say insert wire here lol. Sweet. Thanks! I wonder why it specifies the thread count though.... ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted April 17, 2013 Report Share Posted April 17, 2013 i've been using this tool wrong all along lol This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
HunterJohnson Posted April 17, 2013 Report Share Posted April 17, 2013 its 100% for screws, and what ever else you can use it for! Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 17, 2013 Report Share Posted April 17, 2013 always wondered this as well Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
P4killer_ Posted April 17, 2013 Report Share Posted April 17, 2013 I've only used it a few times. It's not often in car audio I need screws that small to be trimmed.. its not.like it'll cut threaded rod.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s Link to comment Share on other sites More sharing options...
HunterJohnson Posted April 17, 2013 Report Share Posted April 17, 2013 I've only used it a few times. It's not often in car audio I need screws that small to be trimmed.. its not.like it'll cut threaded rod.. You know that screw on the back of HU that you screw in to old cars. Chop that thing down if you need to with the strippers Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
Ben Fultz Posted April 17, 2013 Report Share Posted April 17, 2013 It tells ya right on the tool what their for. Right side of spring. Insert screws this side. Link to comment Share on other sites More sharing options...
Lbox88 Posted April 17, 2013 Report Share Posted April 17, 2013 They're threaded so you can run your screw in, cut the excess off, then you have to unscrew it which will clean up the threads on the end of the screw that are fucked up so it will be able to be screwed into whatever it's for without cross-threading. i've been using this tool wrong all along lol UBL | Build Log Link to comment Share on other sites More sharing options...
Carbon Posted April 17, 2013 Report Share Posted April 17, 2013 Yup I can confirm those holes are used for cutting small screws. Bending wire is also a good idea! Link to comment Share on other sites More sharing options...
kickass audio Posted April 17, 2013 Report Share Posted April 17, 2013 AS previously said its intended for screws only but can be used for other things. Its not a cutter at all since there is no blade but it does break screws apart when you put them in the hold and close on it since its twisting them at a point and breaking it. If you look one side will have threads and the other side will not. You are supposed to insert the screw in the threaded side and then you can clamp the stripper closed to break the screw if you need to shorten its length or you can simply keep screwing the screw in the tool if you have an issue with the threads on the screw. What the other members were saying with bending wires are located near the top where in the pic you see the "12-10 insul" there is no stripping or cutting that can occur in those holes, just insert the stripped wire in there and bend it to make a perfect bend to use when terminating the wire to the outlet/breaker. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress Link to comment Share on other sites More sharing options...
