How do you guys pull out a flush mounted sub?
I have already done it once for the first time, but I used a flathead and did a little damage to the top baffle. Is there trick some of you do to make it easier to remove?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
If you have the height inside the car you could flip the box upright
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
I grab the surround and pick it up. It depends on the sub. I'm sure some subs would come apart lifting them this way . Obsidian gas a tall rubber like surround so they are tough enough to lift then that way
I dont flush mount
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I flush mounted my last build and it was a pain to get my DC level 2 out so I don't think I'm going to flush mount any more...unless I use a removable top baffle to flush it with, which I don't think in going to. It doesn't make it look that much better to flush mount anyway in my opinion.
Lol, I tried picking out up by the surround, not enough to get a good enough grip on. I would have flipped the box, but had no Allen keys where I was at and was in somewhat of a hurry. I try that next time though.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Just a thought but before mounting the sub put a stong string or something behind the gasket so when its time to pull sub out just pull sting. Kind of like the string/strap behind batteries in remotes.
If it's worth building, it's worth over building.
Put a rag under where you pry up on the sub, to prevent damage to the baffle.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
If you still have the gaskets on use those. Just lift up on the gasket to till you can put something underneath then use finger tips for the rest. In a wall the subs is pretty much going to remove itself after a little prying.
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
