Skar Audio ZVX-8 D2/D4 8" 900 Watt RMS Subwoofer Specs & Information
Hello everyone,
Skar Audio brings you the meanest, loudest, and most powerful 8" Subwoofer we have ever designed with the ZVX-8... This is a behemoth of a subwoofer and rated at a conservative 900 Watts RMS, with the capability of getting extremely loud in a single daily setup or to be used in an array of applicaitons for competition use. The woofer is very responsive and features parameters that allow it to not only get very loud but also sound great while doing so. Engineered with the expectation that customers are going to want to throw everything they can at these stout little monsters, we did the same.. The ZVX-8 features an advanced cooling system that allows it to maintain the best possible temperatures even at the highest power ratings, as well as a competition grade high temperature voice coil for maximum efficiency.
MAP Price : $209.99
MSRP Price : $319.99
Available in D2/D4 Voice Coil Configurations
Technical Specifications
RMS Power : 900 Watts
8" ZVX Competition Level SPL Subwoofer
2.5" High Temperature Voice Coil
Triple Stack Ferite Motor Slugs (160mm x3)
Competition Grade Paper Cone
High Quality Foam Surround
Poly Cotton Spider
Ultra Low Distortion Design
Magnet Weight : 160 Oz
Heavy Duty Speaker Push Terminals
T/S Parameters (D2/D4)
Fs : 45.3 / 44.1 Hz
Qms : 3.93 / 3.86
Qes : 0.49 / 0.51
Qts : 0.42 / 0.41
Nref : 0.08 / 0.076 %
Bl : 18.9 / 16.6 N/A
Spl : 85.2 / 85.3 dB
Vas : 5.18 / 5.898 L
Enclosure Recommendations
Ported : 0.8-1.0 Ft^3
Sealed : 0.9 Ft^3
Displacement : 0.12 Ft^3
Depth : 6.5"
Outside Diameter : 8.7"
Cut-Out : 7.5"
Magnet Diameter : 6.5"
Visit SonicElectronix.com or SkarAudio.com to order today! Free Shipping!
Edited by skaraudio
  • Like (+1 Rep) 4
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
Hello everyone,
We are proud to announce that we will be soon completing prototype testing and development on a new, highly anticipated subwoofer : the ZVX-8.
The ZVX-8 is a behemoth of a subwoofer. Do not let it's size fool you - this 900 Watt RMS 8" Subwoofer is going to set the standard in the 8" woofer market. We started from the ground up and designed this subwoofer to out perform all your expectations of an 8" Driver. The basket is custom tooled and in part based on part of the VVXv2 design. The motor, a triple slug 160mm ferrite magnet, provides a whopping BL of 22.3!
Furthermore, the woofer features a custom tooled competition grade paper cone to go alone with the custom high roll foam surround for superior SPL. The ZVX-8 was designed to be an all out SPL monster and works best in ported enclosures. This woofer will be released in Dual 2 ohm and Dual 4 ohm models.
ETA : 8/15/2013
Estimated MAP Price : $209.99
Magnet : 160mm * 3 PCS (Ferrite)
15mm Top and Back Plate
Fs : 46.3 Hz
Qts : 0.415
Bl : 22.3
Spl : 85.3 dB
High Roll Foam Surround
We will have more pictures/specifications coming soon!
:shok:
holly fuck that things a monster
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
  • Who's Online   1 Member, 0 Anonymous, 1540 Guests (See full list)
