aiming for a 7k watt system
Im trying to put together a new system for my car. Im aiming for about 7k watts what electrical needed for that? i already have a high output alt,i bought it from mechman last year so i cant remember if its a 260 or 270 amp
couple d3100 batterys, probably 3 runs of wire front to back...Maybe more, somebody with more experience will chime in. XS power used to have a battery chart that would show you the batterys needed per wattage
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
Already got the alt, so fit the biggest xs battery you can under the hood, 4 d3100's in the back, and yes, probably 3 runs of power going to the rear batteries.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Never satisfied with his chrystler 300, I think had 1 300 amp alternator, with 21 Xs power batteries. I think he had 9k and dropped .1volts full tilt. Not saying you should have 21 batteries... But I am saying if you can't supply with enough alternator amps then you need to supplement with (more batteries) then your system should have.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Sorry but I'm not buying that xs power chart. No way the D7500 can support a 7k system on it's own. It may be a good battery but it's not magic.
As others have said: couple group 31s. Don't skimp on wire or fuses and you should be good to go. As with everything, keep an eye on your voltage
Will I need a bigger alternator or not?
Your 270a alt should be fine
I think their chart assumes you have sufficient power coming from the alt to also support the potential amp draw.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
It powers a 5,000 watt system. The 7,500 is on the left side of the chart which is if the battery is a secondary, meaning it is assuming you have a decent starting battery and alternator.
  • Who's Online   0 Members, 0 Anonymous, 1170 Guests (See full list)
