Power Wire Under Vehicle
I have one run of sky high i have it split loomed just incase been there for about a year no problems its just zip tied to the frame
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
to many copper thieves here if they see some big copper wires there just going to see money so i use the loom as a bit of protection but mainly try help it blend with factory vehicle loom
Conduit, PVC, garden hose...
The most important part is finding a good route for it. You have to have a shit ton of (good) places to zip tie it to on the way back. And somewhere kinda tucked away. You don't want the wire to end up being the new lowest point under the vehicle.
If you sre running wire where a thief can see it you should look at your install first. Mine is all tucked insude the inner frame rail you have to be on your back undernesth to see it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
we have thieves that will drill out your gas tank and if they see a jucy copper wire well there under the vehicle its just bonus dollers
use a piece of 3/4 pvc to sleeve the wire if your worried about it
I've seen people do this for each wire keeps them from touching just in case something cuts the wire an if it was me I would to, have no worries about it pvc is tough and will handle anything
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Well then thats pretty hardcore holy shit
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
ive had mine down there since 2010 or 2009, nothing has ever happened, only ziptied well to the frame up against the floor.
  • Who's Online   0 Members, 0 Anonymous, 860 Guests (See full list)
