Help me do hairticks
jessdabest77
Ok,first,the equipment is two AQ HDC3 15's D2,two AQ2200's,three D34 Optima's,two run's of 0/2 welding cable,and a 2002 Nissan Frontier ext cab truck.I had built it for comp's,and it did well,152.7db,but now I'd like to see it do hairticks.I never could with the old box set up.I'm not really into competing anymore,just trying to play low and of course,the hairtrick's.What can I do to achieve this.The old box was 8cf,with 130 sq. in. of port,tuned to 38hz..Sub's and port up.Can it be done?Thank's in advance.
Everyone is pretty much dead on,140sq"/8 cubes/30-32hz
Might want to look into a high output alt if you don't have one already,them low notes can be much harder on your electrical,you already have the right stuff,just new enclosure!
Thought hdc subs did not like to be tuned low?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
there's this myth out there about dd/aq subs.. they are loud as shit when tune to 37hz/38hz, that's like most people daily/spl box. but i have seen alot of people who love the lows more than anything get a hold of hdc and dd9500s. and they also destroy the lows !! dont let the high FS scare you, i think thats before break in..
but my old dd9500 10s murder the lows..
so you can tune it low..
its all in the box and installer !!!!
I really can't speak much for what to do for hair tricks and stuff because I can't do one even with my big ass box and port area I have with a 30Hz tuning. It ruffles your hair but doesn't do a hair trick or shirt trick but it will flex the shit out of all the windows, doors, hatch roof, really any part of my truck with a single 18. I was really sad but it sounds pretty good for it so im fine with not doing hair tricks for the sound of it so don't be sad if you can't get one in yours.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
It's possible I know a guy local with an ext can ranger that does mega hair tricks with 2 skar 15s sub up port up, don't really like skar equipment but it gets the job done
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
I agree its a myth my hdc3 12 kills around 32 hz i can't play lower then 29 tho (box is tuned to 36hz)
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
AQ fs is on fresh out of the box subs. As they break in, it gets lower. Look at The Black Nasty, insane hairtricks and lows. Like they said, tune low like 28-30hz and LOTS of port area. Subs and port up would probably be best, but in my Dodge Dakota I had subs forward and port up with 2 15's on 3k. It could pull a small hair trick but was tuned to 34hz
  • Who's Online   0 Members, 0 Anonymous, 440 Guests (See full list)
