Aj11 Posted November 28, 2013 Report Posted November 28, 2013 I've heard 2 different sides on what the best ground Is for your amps. one is as short of a wire possible to the frame of the car with the paint sanded away. the second is running a fat wire back To the negative of the battery. what is the best? most people i talk to run there ground to the seatbelt. i just want the best possible don't care how hard or much it cost, thanks for the help jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
tacomaguy1 Posted November 28, 2013 Report Posted November 28, 2013 How much power And this has been discussed a lot before Team Flex Issues
Broke_Audio_Addict Posted November 28, 2013 Report Posted November 28, 2013 Best way to find out is try both and see what works best for you, every situation is different. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
sprkn_ranger Posted November 28, 2013 Report Posted November 28, 2013 http://www.stevemeadedesigns.com/board/topic/171708-fact-and-science-have-no-place-in-car-audio/ Look at this thread...specifically myth #2 and #4 Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Aj11 Posted November 28, 2013 Author Report Posted November 28, 2013 right now i have 1000w rms, i watched the video and was shocked! 14% wow! i have 2 more questions 1, if i have 2 amps with 4gage outs for the ground can i run them to a distribution block with 0gage out? ( 2 4g in one 0g out to the frame) or should i just have each amp its own ground? 2, what if you have a second battery in your trunk And you don't need a 15ft cable. would the volts still drop so low considering there's less resistance jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Tarball Posted November 29, 2013 Report Posted November 29, 2013 right now i have 1000w rms, i watched the video and was shocked! 14% wow! i have 2 more questions 1, if i have 2 amps with 4gage outs for the ground can i run them to a distribution block with 0gage out? ( 2 4g in one 0g out to the frame) or should i just have each amp its own ground? 2, what if you have a second battery in your trunk And you don't need a 15ft cable. would the volts still drop so low considering there's less resistance If your amp is close to the battery and your battery is properly grounded then you should have no issues with a short ground to the batteries. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
alaskanzx5 Posted November 29, 2013 Report Posted November 29, 2013 do some searching.y on the forum. there was a thread with a lot of info on this. A member on here that is known very well for books and always giving.the best advice for electrical posted several threads talking about the electrical system on a car. Let's see.gov long it takes people to figure.out who. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
775Tundra Posted November 29, 2013 Report Posted November 29, 2013 Snafu? 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Aj11 Posted November 29, 2013 Author Report Posted November 29, 2013 thanks for all the help guys, I'll start hunting jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
