Wicks Posted December 3, 2013 Report Share Posted December 3, 2013 Dual probe oscope is how you find actual output without the amm-1. And you can NEVER have the current and voltage in phase in a AC system. That would be 100% efficiency or a power factor of 1, doesnt exist. Oscope is only way to see at what point in time each current wave and voltage wave is doing at the same time, then you can calculate phase angle, take cosine of that angle and get power factor, bam there is your efficiency. WHOA.... I think you're mixing up efficiency and power factor. Sure you can have the current and voltage in phase in an AC circuit. Take a non-inductive resistor and plug it into an AC outlet, everything is in phase. In fact that's exactly how the AD-1 works. It applies your amplifier output (AC) to a very large resistive bank which keeps everything in phase and is able to measure output power in a worst case scenario (constant load across all frequency's). Power Factor is the ratio of real power in a system to the apparent power. Resistors (ideal) have a PF of 1 as all power is real. Capacitors (ideal) have a PF of 0 since the phase angle is 90deg and there is no real power dissipated. Efficiency is a ratio of the output power in a system to its input power. Since there are no perfect conductors, you can never have 100% efficiency. WHOA!!!! WHOA!!! WHOA!!! I think you just made my brain hurt. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
Kyblack76 Posted December 3, 2013 Report Share Posted December 3, 2013 WHOA WHOA WHOA !!!!.... Wicks ! Op said, dont be a smart ass....... jeeez... The OP be like - fuck why did i even say anything. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
CJ18 Posted December 3, 2013 Report Share Posted December 3, 2013 There is very little science behind what I am about to say, but so far it has proven to be pretty close. All of the Class D Amplifiers I have tested on the AD-1 so far have be 65%-75% efficient at 1ohm and 2 ohm. Based on some old "clamped" power testing I did, taking roughly 70% of those numbers and comparing them to actual dyno testing, they have been pretty close. Link to comment Share on other sites More sharing options...
audiofanaticz Posted December 3, 2013 Report Share Posted December 3, 2013 There is very little science behind what I am about to say, but so far it has proven to be pretty close. All of the Class D Amplifiers I have tested on the AD-1 so far have be 65%-75% efficient at 1ohm and 2 ohm. Based on some old "clamped" power testing I did, taking roughly 70% of those numbers and comparing them to actual dyno testing, they have been pretty close. If your not aware, those class D efficiency ratings of 80 or 85% are only when the amps at 4ohms, they drastically drop at 1ohm and below. Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted December 3, 2013 Report Share Posted December 3, 2013 I believe he was accounting for the drop in efficiency from 4 to 1-2ohms as stated above. 65-75% sounds about right for a class D at 1ohm. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted December 3, 2013 Report Share Posted December 3, 2013 aaannndddd i just saved a bunch of money by just driving da fack off When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
Dd9515 king Posted December 3, 2013 Author Report Share Posted December 3, 2013 Kylar your very right. I think i didnt ask my question right. An ad-1 will tell you what your amp puts out at 1 ohm. If you wire to 1 ohm but rise to say 3 ohms. If multiplying amp and volts does not get you watts then how can it get the right impedance? Link to comment Share on other sites More sharing options...
AMI CUSTOMS Posted December 4, 2013 Report Share Posted December 4, 2013 Holy shit, I guess i need to specfiy since we have experts around these parts I was referring to in a car, amp hooked up to a sub, you willl NEVER EVER FUCKING NEVER have 100% efficiency or a power factor of 1. WHOA WHOA WHOA lol TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
fecupe2001 Posted December 4, 2013 Report Share Posted December 4, 2013 whoa whoa thank god i´ve learned how to get loud without actually learning anything about things like this lol I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/ Link to comment Share on other sites More sharing options...
Dd9515 king Posted December 4, 2013 Author Report Share Posted December 4, 2013 Ami can we talk this weekend about this? Link to comment Share on other sites More sharing options...
