Dual inputs worth it?
There was supposed to be someone on here doing some testing on those exact questions using a Amp Dyno but I can't recall if the tests were ever completed or what the results were. Have you guys tried searching for this topic?
I own them and use them for the peace of mind. IMO if your electrical is lacking in any way shape or form then dual inputs could prolly not help to their fullest potential anyhow.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Doesnt hurt but its questionable how much if any it helps
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
It was cj that did testing.
and they didnt help.
Most people with a rear battery by their amp(s) wont see a difference since your amps power wires are so short and a 4 foot power wire can handle so much amperage (compared to the normal rating of about 300amps at 17ish feet).
the only time multiple inputs on your amp would help you out is if your battery is in the front of your car, and you have a huge amp in the rear, at that point running multiple runs to that amp is needed to reduce the voltage drop per run of wire. Perfect example are street a and b cars for db drag, 1 battery, 2 big 10,000 watt amps powering 2 12s off one d3100 or similar size battery under the hood with the car off and the stereo just goes burrrrrrrrrrrrrrrrrp
In my shit... dual's do nothing.
If you gained from a dual, then you were lacking before.
This...
I also noticed those that claim duals made a huge difference are also those that say ofc wire is the best wire and running multiple runs of cca is a waste of money even tho its cheaper in most cases and cant handle way more current..
but yet they put these dual input blocks made out of aluminum on their amps and batteries, only to say aluminum wire is junk..
laughs
If a single delivers the current being consumed by the amp then don't waste your money. Having a dual there only means that more current will be available but the amp is still gonna draw what it needs and that's it. It's not like the dual is force feeding it more current. It's not a super charger or turbo that force feeds. Another way to put it is like having a Throttle body that can flow crazy stupid high CFM. If your intake cant handle x but your TB can flow y your still limited.
Rolex you sicken me.
Just let me finish my pie
~ Juice
  • Who's Online   3 Members, 0 Anonymous, 876 Guests (See full list)
