Removing tranny fluid from Metal
I'm sure most of you don't remember but when I bought my truck I ended up throwing a tranny rebuidl at it. Not once but twice. The first time it leaked and got tranny fluid all over the place. I'm going to por15 my frame in the spring but I just looked and there are still traces of tranny fluid on the frame. I have no idea how the hell to get it off short of a torch and burning it off. Obviously that's not high on my list of shit Id like to try. Anyone ever had an experience like this? I dont think the por15 will stick to the spots that has fluid residue on it still.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Try high temp steam. Should work.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Carb cleaner will take it off no problem. And then I would use some simple green on it to make sure there is no residue left.
i use either a citrus degreaser OR brake cleaner (non chlorinated)
i use the citrus degreaser at work all the time for insurance jobs....its what they require to get all the oils off the bottom of a car that either blew the engine or got into an accident and put a hole into a pan of some sort whether it be the oil pan or tranny pan..... works like a charm...... the stuff i use is in an aerosol can and the can is tall white with blue..... i get it from napa.
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
What i usually use at work for situations like this is a strong carb cleaner like (Chemtool B12) or i also like to use Xylol and Brake Kleen. Just becareful when using those chemicals is because they will eat through plastic and rubber like nothing.i get a brush and wipe it back and forth with a Xylol mixture, then spray it with brakekleen. It gets it nice and dry
do you have access to a air compressor? What we do at the shop is spray with carb clean or brake cleaner then blow it of with a air gun. Depending on how big of the mess is we soak with a degreaser at 100% concentrate then pressure wash. What ever is left we do the brake cleaner or carb cleaner and air gun.
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
Power washer wouldn't be able to take that off?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
No, just a power washer won't. Even though tranny fluid is pretty much just detergent, it is still some nasty shit. I had a puddle on my driveway after doing a clutch and it took me 6 washes of muriatic acid and a power washer to remove it
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Damn, never realized that. I know with concrete though, that shit is porous so oils and fluids are the worst to get out of. Experienced almost the same as you before. sorry for thew offtrackness, hope you get your answer n8
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 977 Guests (See full list)
