yeah metallic paint is tricky, and in the end you will look back and be like wow I built this and did all this, and it looks awesome!
That's the goal. :) thanks again for the info.
Smoove, I'm still out of town but will be coming back Tuesday I believe. I can help you through this. 3M makes those flexible sanding blocks, that are about a quarter inch thick. That make a black and gray one. 3000 grit has been out for quite some time. You REALLY REALLY need to watch your extra, as previously said, to avoid burning through it with either sanding or the buffer.
Did you get down to 800 grit on the primer layer before laying the white? Any scratches you had in the primer could come through to the paint layer. You're definitely on the right path and I think it's going to come out very well.
P.S. I'm glad Danny came clean and told you his was done with auto paint. It works have been hilarious if he'd let you think it was rattle canned :P
Anyways, I'll hit you up when I get back to town and maybe I can come over and supervise with a Coors light in one hand.
Also, the metallic is in the port, getting a buffer to it will be pretty impossible. If you've sanded down to 800 before the last coats, it should be enough to eliminate scratches. You shouldn't see any problems down that dark port as long as you're sanded down enough :)
3000 sand paper is typically a tyvec pad
I wouldn't be sanding anything that I spray painted with more than 1000. Even that is a little much you will take the clear off every time and you will always have to re spray over it for the best result
When u spray paint I got 1500 2000 then tyvec pad
1000 will take the paint off if your not safe
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Good looking box. Be carefully with the water on the inside of the box if the wood isn't sealed or painted. I guess you would know that so forgive me for the obvious comment.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Just a little FYI for you, notebook paper is around 3000-3500 grit. I've seen guys going for that extra bit of flatness, sand with notebook paper. The problem with it, is that it doesn't hold up and will fall apart after being wet for too long. A buffer will do just fine though as it melts down that top layer flat.
pretty much what everyone is saying, wet sand, buff wax, electric or air pneumatic buffer will greatly speed up the process.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
good tip did not know that.
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
3000 grit must be like sanding with a baby's butt
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
  • Who's Online   0 Members, 0 Anonymous, 886 Guests (See full list)
