installing stinger voltmeter into dash?
Skax
get a small piece of window tint to put on the inside of the lens and you should be good
2 12" Jeff Vue Customs
1 set MB Quart FSB 216 in doors
1 American Bass 100.1 on sub
1 Hertz EP2 on doors
JVC deck IPOD control
Stock 105 amp alt
DD-1
big 3
new build in Chevy caviler http://www.stevemead...chevy-cavalier/
last set up in the ZX2 http://www.stevemead...-current-build/
old build log http://www.stevemead...-1998-ford-zx2/
Gold is the money of kings, silver is the money of gentlemen, debt is the money of slaves. Just my .02c
that shop needs keep those doors open so they have to charge for it
if people think 10k is a lot then they should get into other hobbies.. like masturbating, cause any hobby cost money to maintain
Lol no, I'm smarter than that bro haha. Fool me once, shame on you, fool me twice..............go fuck yourself lol
If your intent is to monitor the voltage at your subwoofer amp you need to have the power input for the meter wired directly from the subwoofer amp's terminal. If you only care about general system voltage then you can get the signal from the head unit.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
which one would you run off of headunit or subs amp?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
I'd really like to know:
Does it make a difference if the positive is on the amp but it's grounded at the headunit?.....Does the + and - need to be on the amp or just the + ?
97 Suburban
8 custom PSI Platform 3 18's
Me too
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
I used 14ga speaker wire for mine
For what it's worth: Mine is 2 years old and working great.
Your positive and negative should be at whatever you want to read from. Ideally from the same spot, so you eliminate voltage drop through grounds and don't give yourself a false reading.
Amp, battery, alt, etc
Ive had mine for like 5 years, just recently it leaves a digit stoll half lit or w.e even with the car off. I just disconnect and reconnect. No biggie. But for years it was 100%
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
I used some sky high 14ga to run mine...a little overkill.
Run a switch with the remote wire too. It's bright as fuck and a half. No sense in having it on say at night, when you're driving through a neighborhood without the volume turned down.
Cmon... its not thaaaat bright..
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
