Amp Ground Length ?
Is it ok to have a 5 to 8 ft ground ? basicly im trying to clean up my all wiring in the back of my truck. Shits all over the place and it looks like a rats nest.
there would be like 4 to 5 ft of 4ofc( at The furthest amp) to a distro block to 3 ft of 0 ofc to frame.
Thanks
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
The shorter the better.
truthsayer
Eh, ... I have always been shown/taught ... (& have bulit as such) ... that unless you are running your GND/NEG all the way from your front BATT with your POS runs, then your AMP GNDs should be 12-18" long, & really no longer ... even if they go into a distro box, & out from there to a chassis GND point. I do not think many folks are going to stand behind 5-foot-plus AMP GND lenghts ...
No way you can ground AMP, or each AMP, separately to within 18" directly to the chassis of your vehicle?
EDIT: Like the guys said above, ... & as was my point(s), ... the shorter the GNDs anywhere, the better.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
I could, i was just trying not to punch another hole in the floor..If i have to i will though..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Where are you planning on installing? There might be a good bolt already in the truck.. I got lucky with my car. I used one of the factory bolt locations as an additional ground my rear battery.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I plan on building a rack just behind the driver/pass seat on the floor. all the power ground is on drivers side.Seat bolts wont come out,heard it wasent a good ground anyway..Im just going punch a hole and go to the frame i think it will be best
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
ground distance means nothing. i regularly use a 3-6ft length for ground. good grounding point means the most. test every point you are considering using.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
