Deadly hertzz Posted April 21, 2014 Report Posted April 21, 2014 8 sa 12s on one saz3000 at .5 demoed all weekend at the tdh show in va then right before I left I gave a demo and noticed a froze sub not moving this the second sub that's done this (given they were both used before I got them) don't understand how it happened especially on just that one amp subsonics set around 30 low pass 80 and I set the gain with my dd1 and never go past my designated clipping point on the head unit, coils look perfect and subs don't even get hot 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Deadly hertzz Posted April 21, 2014 Author Report Posted April 21, 2014 Also used -10 track to set Gain and pretty sure it happened playing white clouds 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
MrSkippyJ Posted April 21, 2014 Report Posted April 21, 2014 where sub is located in regards to the port maybe? could be lots of reasons. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
DrewJones Posted April 21, 2014 Report Posted April 21, 2014 You got to much................... Not really, just seemed fitting. What kind of music were you playing? TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
n8ball2013 Posted April 21, 2014 Report Posted April 21, 2014 That -10 only way is to overdrive them THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
SnowDrifter Posted April 21, 2014 Report Posted April 21, 2014 Was it frozen or stuck pushed-out? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DubNDodge Posted April 21, 2014 Report Posted April 21, 2014 you tuned with -10db and I'm pretty sure while clouds is recorded at 0dB or even +2 or +3db. At least the original one was. Also don't you lose some cone control when you wire below 1 ohm? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
SnowDrifter Posted April 21, 2014 Report Posted April 21, 2014 you tuned with -10db and I'm pretty sure while clouds is recorded at 0dB or even +2 or +3db. At least the original one was. Also don't you lose some cone control when you wire below 1 ohm? Impossible ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ChevyBoy95 Posted April 21, 2014 Report Posted April 21, 2014 White clouds is like -3 or -4..... But only thing i could think is maybe it unloaded, which caused complete loss of cone control and it hopped out of the gap. Is this by chance a corner sub? edit: and if you play decaf, use the -5 db track. Most Decaf hovers around -5 to -3db. If you do with -10 you will be in a HEAVY clip constantly at full tilt. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
