where are all of the diesel guys
Mine has about 1 1/2" squat i have 10" in the front with 5 1/2" blocks in the back. Good looking truck too, how loud is that 5" exhaust? I stayed 4" but have it dumped behind the rear differential and im changing it back to stock dump asap, its wayyy too loud
Thanks man! Your truck is sexy as fuck. Its not that loud, i have it dumped right now, til i get a tip.
With my lift it looks like they put 3 shims on top of the stock blocks. so idk if i can take 1 out from each side. Sometimes the truck looks like its facing down
@Broke_Audio_Addict [/size]
i don't want it to squat. i just don't want the front sitting lower than the back. id rather have the back lower
Could you throw some bags on it so you can level it how you want it?
Watch those curbs guys, don't want y'all scratching a rim.
Thanks for your concern sweetheart but i know how to drive my rig.
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
The dodge and tow mirrors always gets me laughing. I think they look weird without them flipped, but that beavis pic had me actually laughing out loud. When they aren't flipped up they look really un-aggressive especially when your running a 12 or 14 wide they almost have to be flipped or look really un proportionate
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Love driving a diesel daily. My 07 had built motor and built trans but I enjoy my 12 more. 100% stock and still as almost as strong as my built truck was and is the most quiet diesel I have every driven.
BTW that dodge is badass. Makes me wish I had went with 14's.
36229DA5-0088-4696-B580-648203292A81_zps
f7563926-9992-4cf0-93e3-44be8a73dae9_zps
2012 F250 Lariat 6.7, lifted on 22's and 35's
4 DSS Ethos 18's walled tuned low
2 Ampere Audio 7500.1's, Ampere 125.4
Rockford Pro Audio front stage
9 batteries, Mechman Elite 370 alt
Team DSS, Team Ampere Audio
2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
32d73d87-e373-4a49-8914-d25decfa6dcc_zps
some bad ass trucks on this thread guys
Build Log
1996 chevy suburban
2 zv4 15
kenwood excelon mids and tweeters
kenwood excelon deck
mevhman 370
3 batts all different
mechman avmb II
2 inch squat
33 inch muds
straight pipes
kixker zx series 4ch
sundown amps
memphis 0 gauge
soon to be fu audio c pillar wall
*waiting for Jon to show up with his tow pig*
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Not hating on any of you guys cuz non look that bad but why do you do a lower profile tire on a big lifted Truck? Why not stick with lower 20s and a bigger meet tire? Fill the wheel wells. Sorry just a pet peeve of mine to see people riding with a nice truck and lift and have stock sized or slightly bigger than tires but a big rim on it. Ig I'm a fan of meety massive tires. Once again none of you guys are to that point that Pisses me off. I just want an answer.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Wtf is rolling coal?
Blowing black smoke out.
on purpose? doesn't that mean there is something wrong with the engine?
So how much of that is real? People change it on purpose or was that part of the satire?
Gotcha
so it's like overkill
seems like something most of us can identify with!
I am most likely wasting my time with this one. Look up what turbo lag is. And then look up what Diesel turbo lag looks like. So a properly tuned diesel doesn't "roll coal" IMHO. Then if you look at any diesel drag racer or tractor pull truck its blows black smoke for a minute or two and then runs like a bat out of hell. What is happening is they are usually running a really big turbo that takes awhile to spool and needs a lot of heat and pressure to turn at the optimum psi or pressure. On most passenger diesels its because the stock turbo can't provide the needed spool up to clean up what the injectors (fuel) is dumping into the cylinders.
most fuel means faster spool up and more power. Turbos work on exhaust of course.
Gotcha
Install propane injection and nitrous to spool the turbo ...
