Amp help please guys
jarrius
Yes they say it should only pull about 60 or so amps but in heavy bass music it can pull up to 100 amps.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
1200 watts / 12 volts = 100 Amps
it's recommended to go one fuse size above the expected draw
having said that.... i don't think it should be pulling that kind of current when you're just installing it... so sounds like a short
just put a regular ANL fuse in it. Those circuit breakers are finicky as hell and generally will pop, in a home electrical environment, at 85% load.
Who is "they"
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I had a similar problem I put the terminals backwards.
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
They is Rockford fosgate and its dead verified it for sure. I know what killed it and it's over. Just need to buy a new amp now
141 on music.
So what killed it?
Builds:
So what killed it?
This. Im interested
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
