Broke_Audio_Addict Posted March 4, 2015 Report Posted March 4, 2015 Should also ask what brand of wire and do you know if it's ofc or cca? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
aculous Posted March 4, 2015 Report Posted March 4, 2015 This could help. That's for power wire. Speaker wire is a bit different. Higher voltage, lower amperage interesting didn't even think about that.
Kyblack76 Posted March 4, 2015 Report Posted March 4, 2015 Skip the terminal. Drill a hole through the box, run the wire through, seal it off with hot glue this SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Mr DeeBeez Posted March 4, 2015 Report Posted March 4, 2015 Skip the terminal. Drill a hole through the box, run the wire through, seal it off with hot glue this x2 Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
SnowDrifter Posted March 4, 2015 Report Posted March 4, 2015 OP said it's hot where it connects to his box terminal. That's the source of resistance. Eliminate the terminal and run the wires straight through, no problem. If the entirety of the wire was getting hot that'd be a different story ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Kyblack76 Posted March 4, 2015 Report Posted March 4, 2015 OP said it's hot where it connects to his box terminal. That's the source of resistance. Eliminate the terminal and run the wires straight through, no problem. If the entirety of the wire was getting hot that'd be a different story fuck that... 2/0 ofc from amp to speaker dude.... fuck... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted March 4, 2015 Report Posted March 4, 2015 OP said it's hot where it connects to his box terminal. That's the source of resistance. Eliminate the terminal and run the wires straight through, no problem. If the entirety of the wire was getting hot that'd be a different story fuck that... 2/0 ofc from amp to speaker dude.... fuck... ^^This guy.... ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
CleanSierra Posted March 4, 2015 Report Posted March 4, 2015 OP said it's hot where it connects to his box terminal. That's the source of resistance. Eliminate the terminal and run the wires straight through, no problem. If the entirety of the wire was getting hot that'd be a different storyfuck that...2/0 ofc from amp to speaker dude.... fuck... I love this guy. Im not the one you want to try to troll. Just a fyi for you.
HHR Ed Posted March 5, 2015 Report Posted March 5, 2015 Most likely it's a weak connection at the terminal. Drill a small hone, squeeze the wire through, and terminate direct to the woofer, then seal the wire hole with goop. Just as said above. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
