Second battery question?
Wow,ok,I did disconnect the power wire in the back battery,and it read's the same as the front. I also checked all my connection's,and they are tight. Now,what "reedal" said on resistance,I do not know how to do that. What do you set your multimeter on,to do that? That sound's like it might be it. Also,the wire I am using is CCA,would that make a difference? Man,thank all of you guy's for your help.
There is a bad connection between the front and back battery, so check everything inbetween. Usually it's a fuse holder or bad connection. Or something is drawing power that shouldn't be drawing power.
Ok,I do not have a fuse between the line,just straight from front to back. And,what's funny,at first it read the same in the front,and the back,but then changed reading's now. Both battery's are good,and so is the amp's,I had the battery's checked at XS power,and the amp's at Soundquebed. This is a new one for me.
No matter what the problem ends up being, fuse that run from front to back (one right after front batt and one right before rear batt).
Singer Alternators
Team Asshole
#anothershittysingerbuild
your asking for it...
didnt really read anything else...
but a front to rear run thats not double fused....... im waiting for the "i burn my car down" post..
  • 1 month later...
Well since this thread was brought back to life...
You set your multimeter to resistance (the setting that has the ohms sign, the Greek letter omega). Just a tip, you might want to know how to work the tools you use.
Tuned to find the resolution
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
