whats even more interesting to know is, are thos only a svc and not a dvc? either way, i like the solid core wire idea. could make it fancy.
Yep that's all Sundown is offering on the X6.5sw for now is a single 4ohm voice coil. I heard talk they are working on a V2 of this little sub but I haven't heard any details on it! But being that it is single 4ohm coils my final Ohm load will be 2ohms how I'm wiring it and that's OK cause my amp don't care if it is 1ohm or 2ohm that's why I went with the RF T2500 It give's me the flexibility to play around with ohm loads! The Blue Print's that are further up will be hold down brackets for the wire so I can make sure they stay put and evenly spaced!
Messing around with some wiring Ideal's, I'm thinking of using solid core 10AWG wire to wire all 8 of them up. I will use White & Blue color wire & bend them all to the same shape after I make a jig to bend them in so I can make sure they are all the same! This was just a test run to see what it would look like! I LIKE IT! B)
I like it too!
The Build starts this week!!!!!!!!!!!!! I will be sure to post pics & videos as I go!!! Hope it sounds as good as I think it will! :P
I am tuned in for this!
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
I SCREWED up yeasterday!!!!!!! I pulled my X10's out to get ready for the 8 X6.5's, and thought I got this old box sitting around so I'm going to sit it in there just to see what it would look like with 11 of the X6.5's sitting on it. WELL DAMN!!!!!!!!!!!! I LOVE the way it looks B) !!!! Might have to go back to the drawing board just to recalculate some thing's!!!! I know I cant run 11 of them cause it would be a crazy OHM load but now 10 of them wired in a series parallel would give me 1.6ohms by my math! Correct me if I'm wrong on that, been awhile since I ran multiple subs!!!!! Would still be in a 4th order!
:morepower1:
Flipping awesome!
Past rides-
Getting started!!! Some times you got to go backwards to go forwards!!!! If all goes as plan I will post a TEST video Saturday!!!!!
Getting some more work done! Bunch of wiring yeasterday! Now today box build!!!!
11219254_928344830518976_218761729181249
11150688_928380207182105_203855974512450
11193336_928330157187110_603252922133186
11204929_928382970515162_400900325230525
My Boy Jared Gibson from JeefWorx is hooking my box up!!!!!!!!!!! Will be dropping the subs off to him tonight! COME ON SATURDAY!!!!! TEST TIME!!
11109506_1079181902098879_52042487006001
11219525_1079181728765563_55619001587026
11165284_1079181965432206_72478772798630
