Time for a little update.
I sent my order for a VM-1 and D3400 in to SHCA, just waiting for a reply, and once that's taken care of and arrives, I'll be able to have some boom again. I also got a b&d 20v cordless drill and 16 ton hydraulic crimper for my birthday, so all of my soldered 1/0 lugs will be crimped as well now. I want to get all of the extra attachments for the drill as well and then I'll be on my way to making my own cuts for a custom enclosure soon hopefully. My PAC OS-2X started that static again this morning, and it increases frequency with the alternator so I think having the HU ground going through that to the stock radio ground is causing a loop, so I'm going to try and ground the 80prs to a new ground and hope that takes care of it. If that doesn't work, I don't know what to do. I'll update again with the results once that's taken care of, and if the problem is still there, maybe one of you guys with the same adapter can throw some help my way if you had the same issue. Thanks.
So here's the hydraulic crimper. Didn't get around to using it before the sunset, so no crimps today.
C7853E5D-E873-4462-9A49-560E6D4C2C95_zps
I fixed my grounding/alt whine issue. Turns out I had some insulation crimped into the wire. All fixed now. But I decided that while the dash is apart, I'd run my RCA's.
Getting them zip tied and tidy looking
A4DCE8A3-EACD-4A05-AD77-63C4C80314C9_zps
Ready to be run
91D5073B-7BC6-4A72-80D7-4D6325E00FEE_zps
Hidden run in the floor trim
D295E075-E805-4329-A187-1D155C65272D_zps
EC71EFAB-6C17-4128-B9A7-42EEAC443D3B_zps
And out to the amps
48675374-43A0-47D0-BA9C-AC87B25E4582_zps
Better picture of the head unit in the dash.
167364D9-99EF-400C-A404-A25A293E91CC_zps
Also got some blue LED's to replace all of the interior lights with (doors, dome, maps, glove box) and white LED's for the license plate. I didn't snap any pictures of the little things before the install, but I'll try to get some of the lighting in the morning on my way to work. Perks of leaving your house at 5:30 :P having blue interior lighting is something I always wanted to try out so I did it. If I end up not liking it, I still have all of the stock bulbs.
Got the email back from Jon with the invoice for my order, hopefully it'll be shipped out tomorrow and maybe be here by Friday :)
Other upgrades I'm in the plans of making sooner than others: smoked headlight/tail lights, HO alt, and getting better at remembering to take pictures.
Edited by reedal
Looks good man, I'm about to put the radio in my dash
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
So here's the interior lighting. It looks brighter in the pictures than it is in person.
From the outside
93938386-E40D-4EDB-8BA5-E5948378163E_zps
Doors
C2640B01-5B12-4E72-9527-00302162CE2D_zps
Map lights
C5E9316C-5211-4808-9C90-FDFBE3FC632D_zps
And dome lighting in the rear seats
2F14A613-06AC-4DBF-84CC-6A50288B7305_zps
It's just replaced OEM lighting, so they only light when the doors open or the buttons are pressed.
Oh, and the D3400 and VM-1 should arrive tomorrow afternoon, so I just might have everything set up in time for the TDH show this weekend, depending on the time I get off work tomorrow and Friday.
Talking to Mike Singer now about a 270 6 phase hairpin. Might run it dual with the OEM alt, but not sure if I'll need to remove anything to do so. Any advice about that?
lookin good! :good:
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Thanks guys. I'll try to get some better pictures of the LEDs inside, these were kinda rushed since I was running late leaving for work this morning. Everything is slowly coming together
  • Who's Online   0 Members, 0 Anonymous, 2425 Guests (See full list)
