Alternator's that aren't $$$$$ ?
So I am trying to find a new alternator for my 2004 Nissan X-terra. Everything I find is over 600 dollars though. I simply cannot justify spending that much on an alternator. My current setup is not huge, as I am only running a sundown sae-1200d atm, and will soon be adding a small 4 channel for mids and highs.
With that information, are there any alt's that you all recommend, that aren't going to cost 600+ dollars?
Spend the money. There is a reason dude.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Buying the biggest alternator allows you to upgrade more later if you want.
This is for my daily driver, and I will not be upgrading the system in it beyond what I already have. I have another vehicle for a balls to the wall build.
Look into an OEM with higher output from auto zone, advanced auto, Napa, or other auto parts stores. I'm sure there's one that outputs a little higher than what you have now. If not, then just add a battery in the rear close to your amp.
The cheap stuff ain't good, the good stuff ain't cheap. It takes power to make power. I highly suggest Singer. Send Mike an e-mail, talk with the dude. He's a great guy. I worked a payment plan through him, and couldn't be happier. Or...like reedal post, add some bank to the back, but it's not as effective as upgrading the alt. <_<
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
I bet if you went to the parts counter at your local stealership, the replacement alt would come out to be more than $600.
Cables and wires almost never fail; the terminations do.
Or real close to it
how big is the stock alt on your truck? your only running 1200 watts so big 3, upgraded front battery, and possibly a rear battery will be more than enough as long as you dont have a tiny alt up front
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
