Box guru's come on in ***Testing completed
DubNDodge
So my new box was a flop. Goal was 25Hz up to 45 or whatever. It peaks hard around 45Hz and drops off to nothing under 32Hz.
My old box had the exact same volume, but less port length and stupid low port area. Same power same subs. I guess my question is, what is wrong with this box, or are the subs specs wrong?
Sub specs:
(Edit: see page 2)***New box 4.55cubes tuned to 31Hz port area is 4.5"x14.5" and 28.75" long bandwidth: 32Hz to 50Hz
***Old box was 4.55cubes tuned to 29Hz port area was 4.25"x 8.5" and 18" long bandwidth: 27Hz to 55Hz
New box
Old box: Note that there was a port plug reducing the port area
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Looks like the port opening on the new box isn't helping the air flow? Seems restrictive
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Have you checked the tuning of your new box to see what you are getting in the vehicle? You can play test tones and look for the frequency that the sub moves the least.
Builds:
your box is tuned closer to 33hz by my calcs. would explain a peak
never mind reaed your entire log closer
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
did you account for port displacement of your new bigger port
Is that 4.55 cuff net or gross volume? What is the displacement of your port? This along with driver displacement subtracts from total volume of the box. This makes your box a little on the small side and causes port tuning to go up.
Pioneer 80PRS
Old box is for a trunk car, new box is not, if you tested each box in different vehicles your results may depend on the vehicles as well, other than that a sketch with dims for the new box would help to recheck it's specs.
One of your subs is unloading directly into the port, that has a bit to do with it. Also, published T/S specs are NEVER EVER accurate. Even with sundown level stuff, there's still a huge variance between one driver and another. Do yourself a favor, buy a WT3, and sweep your own T/S specs.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
You said the old box had stupid low port area, but maybe it was enough. You don't run monster subs with huge amount of power, for SPL comps.
How did you find you had such a narrow bandwidth ?
I have never been disappointed with Ram designs ! But you need to ask the right thing, or to talk to him.
Good luck.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
having so much port area, im sure your response takes a nosedive under tuning. Model it up, check port velocity.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 2985 Guests (See full list)
