ShadeTreeMechanic Posted March 27, 2016 Report Share Posted March 27, 2016 16 ton and adhesive lined heat shrink. Dielectric grease for under hood and under car. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted April 21, 2016 Report Share Posted April 21, 2016 See my thing is what proof is there that these cheap tools are putting out the tonnage they claim? I find it doubtful that they do especially when you consider the fact that tools that cost many times more don't claim to do the same amount of force. It's also funny that a 5 ton and a 16 ton are the same exact size, come in the same case, and both have no markings on them to indicate how much force they produce. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
poorfish88 Posted April 21, 2016 Report Share Posted April 21, 2016 Not sure if they lie about crimping power,but mine crimps the lugs and wire into one solid piece of copper. 16 ton Link to comment Share on other sites More sharing options...
mbdblue Posted April 22, 2016 Report Share Posted April 22, 2016 I have the 10 ton. here's my 2 cents....Ironically I was doing this today. The dies that came with my kit weren't cutting it for me. I have over 50' of Execution Audio CCA 1/0 that fits snugly into a 2/0 lug. The "00 AWG" die wasn't big enough for the lug. So I did a little measuring and drilled out one of the other dies that I know I'll never use (12 gauge). Used a 7/16" bit and did a test crimp, then band saw'ed it in half. Came out solid.... So the best answer I could give is testing the tools to make sure they are doing the job. I did the test mostly because I needed a bigger die to work with, but it was a good experience to make sure the crimp was solid. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted April 22, 2016 Report Share Posted April 22, 2016 Could you cut one lengthwise since you have a bandsaw and open it up to see what it looks like? I'm a little curious about a couple things and I think that might give me an answer. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
mbdblue Posted April 22, 2016 Report Share Posted April 22, 2016 Could you cut one lengthwise since you have a bandsaw and open it up to see what it looks like? I'm a little curious about a couple things and I think that might give me an answer. I threw out the lug side, but I do still have the wire side. Pretty sure there's enough meat on the wire side to show something. I can run it through tomorrow. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
audiolamb6 Posted April 22, 2016 Report Share Posted April 22, 2016 broke i see what your getting at. and if you think about it when anyone cuts the lugs its going to heat up the wire and not really give you a good idea of what the crimp will look like. just my thoughts on it Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted April 22, 2016 Report Share Posted April 22, 2016 broke i see what your getting at. and if you think about it when anyone cuts the lugs its going to heat up the wire and not really give you a good idea of what the crimp will look like. just my thoughts on it Thats why when I cut mine open I cut part of it with a hack saw and the other half with a dremmel cutting wheel for that very reason. I wanted to make sure the heat caused by the friction wasnt giving an illusion of false results Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
MotorCityFats13 Posted April 22, 2016 Report Share Posted April 22, 2016 if I ever get a crimper Ill do this test and cut it with a wet saw at my work Link to comment Share on other sites More sharing options...
audiolamb6 Posted April 22, 2016 Report Share Posted April 22, 2016 good to hear you guys thinking of stuff like that Link to comment Share on other sites More sharing options...
