Too much bass locks up headunit
I just got a Kenwood kdc-x898. I have 4 18s in a wall. Certain songs when up loud will lock it up. Keeps playing music off ipod or usb, but no controls. Only thing i can do is release the faceplate.
Anyone had this problem?
Thanks
I haven't seen this happen but i have seen people glue their faceplate on, so I think it would be most likely that the faceplate is loosing connection.
try pushing on the faceplate near the connector while playing so that contact doesn't vibrate loose and see if you can get the controls to stop working
Maybe try to put some dielectric grease on the back of the face plate contacts
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
That is a bad idea,
Dielectric grease is non conductive and would interfere with the connection.
if you are that loud, take the headunit out of the dash and hold it in your lap when demoing. i have seen it done a ton of times. That or use a zip tie around the whole headunit around the face plate. or get a different headunit
I had this happen a couple weeks ago. Turned the truck off and back on and it hasn't happened since. Not sure why or how to help ya but you're not the only one.
Singer Alternators
Team Asshole
#anothershittysingerbuild
I put a strip of foam behind my faceplate to keep constant pressure on it
That is a bad idea,
It's neither good nor bad idea. It just won't help him here. The grease is nonconductive in that it won't cause a short circuit, but it won't interfere with your pin contact.
I would rather not glue it =] May try putting pressure on it to see if it helps. It didn't do it when I had it part way slid into the trim cage, but when I locked it in, that is when it started.
Thanks, but don't think that will help much.
I was trying to avoid having it in my lap, of course maybe that will be the solution.
That is what I tried the first few times. I have certain songs that will make it do it every time. B Legit - Stick 'Em will do it every time without fail.
prs80 in my rig (i bought 2) did this a lot.....
annoying as fuck..... ... Buddy has a 130 alpine in the dash, and hes WAY more violent than me, and it just plays and plays.......
Zip tie the face plate, like cheezy does, or... get another unit...... :shrugs:
Yeah it is super annoying, especially if I see a cop and it has done it, I can turn my bass knob down, but it still sound like 2 strong 12s with the knob all the way down. And the 4 Sundown 8's in the doors are still pretty loud. Only option I have is to hit the release for the damn faceplate.
That is a good idea, may try that tomorrow.
Thanks everyone for the help.
--David
