12 FI subs on 10K...RF/FI/DC/SMD/XS power...
Stealth AF
IG @walledsonic
Easter Sunday update:  Tried some things today with settings for comparison.  I love messing around with settings and trying to achieve different things, it's my favorite part, apart from actually listening to loud bass.  Everything is just by seats of the pants, to the ear type shit so nothing scientific here....Anyway,
Last summer: 2 DC 5k @0.67 each on 12 FI X series w/ BP option.  Gain overlap -6 (I landed there trying all sorts of different overlaps using DD-1+)
Currently: 3 DC 5k @1.0 each on 12 FI X series w/BP option
Of course all amps are gained matched using CC-1 and LPF set to 80 and Infrasonic set to 20 for this test (normally I keep it either 25 or 28 but I wanted a little more range when doing initial set up for the summer).  As far as ratings go I have 15k RMS in amps running to 9k RMS worth of subs (BEFORE rise).  Electrical is 100% the same, literally.
I wanted to see if It sounded the same, louder, cleaner, etc. from last summer by changing ohm loads and adding an amp.  The percentage that the subs were overpowered stayed generally the same.  Damping factor (cone control) is a little better with the 3 amps at 1.0 than 2 amps at 0.67.  With 3 amps and gain overlap set at 0 it was definitely cleaner sounding (not muddy?)  but no where near as loud.  Shooting right to -7 overlap from there it sounded louder (and moved my interior panels more)  but seemed easier to start clipping so I backed it down some.  With basically the same gain overlap as before (-6) it sounds about the same...Tried -5 but seemed like there was more in it and it never clipped....Unfortunately I cant tell if it's cleaner or not running at 1.0 from 0.67 and it sounds close to the same for loudness.  Of course I didn't meter it some all this means nothing...  So basically the only change as far as I can tell in this daily ground pounder is that electrical holds a little better running 3 amps at 1.0 each as opposed to 2 amps at 0.67 each...whether that is worth the cost of an extra dc 5k is debatable.  The amps are rated at 1 ohm and I knew running below rated ohm load can really draw on electrical so it was interesting to see how much, 10k at 0.67 or 15k at 1.0.  I used to get into the 12's pretty easy and see high 11's when digging and digging but now it seems like I actually hit a small wall again when hitting battery resting voltage, and digging and digging brings me about 1 whole volt higher than before.  This current set up should be easier on ALL gear, electrical, amps, subs, etc.  but was harder on the wallet, lol.
Electrical: two charging systems, stock alt runs stock electrical.  Audio charging system is 1 Mechman 370 Elite powers only the substage, 2 runs of 2/0 OFC from alt to underhood battery XS Power D3400, then 3 runs of 2/0 OFC run to back of Tahoe where 8 XS Power XP3000's sit.  4 runs of 2/0 OFC grounded right to the frame on separate spots in back.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Cool stuff, but I'm still tuned in for dem doors doe...
IG @walledsonic
What's the plan? Tuned in for updates.
Pioneer 80PRS
I saw the FS posts too. Waiting for (4) 18s or somethin ?
IG @walledsonic
Hes going to do 70 6x9's on 20k.
LOL, you kids.  I want big subs again.  I am known as the 15's guy normally.  I had never run 10" before.  Rarely ever run 12".  Mainly run 15" and have run 18" and it's time for me to go back.
Thinking about 2 Team (FI, AA, Sundown) 18's on 2 DC 5K's at 1 ohm each
or 4-15" Mayhems with each amp at 0.5 ohms
Definitely NEED to get my mids/highs going tho really...been lacking in that department for years....
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
There is a little voice in my head screaming "Wall It!!" Lol
Pioneer 80PRS
Tuned in for whats to come.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
