Best way to clean basket? *recone tips?*
I've done about 5-6 recones so far but everytime I clean the basket I do it by hand. Scrape, sand, scrape, sand, wire brush, clean, repeat 100 times.
It always takes super long I know that has to be a better way.
I'm probably over gluing everything but it takes probably two-three hours worth of actual work to get it to my liking.
I don't have a dremel:( Thats all I can think of that would be more efficient.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
^^^ Build ^^^
its soooooo nice with angle grinder. just wear a mask. the ca will turn you in to a little bitch.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
6 minutes ago, catch 22 said:
i use a lathe.  Super easy and takes less than 10 min.
If you're being serious I'm going to need a picture
I went and bought a dremel, little rinky dink one for 50 bucks. I know this wont be my last recone so why not.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
^^^ Build ^^^
Grinder and an orbital sander
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yeah i just use a grinder and put in work
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
drill, zip tie and wire wheel, change directions every now and then. put the zip tie about a 1/2" from the end.
http://www.homedepot.com/p/Avanti-Pro-3-4-in-End-Wire-Brush-PWW075ENDD01G/202831064
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
I use a chisel and a hammer to break loose the spiders and pull up as much as possible, and a razor blade to cut off as much surround as possible.
After that right angle grinder with a 80grit flap disc to clean the basket down to aluminum. Usually takes about 10 minutes or so per basket.
  • Who's Online   1 Member, 0 Anonymous, 1019 Guests (See full list)
