6th order bandpass ratios?
dylan117
I've seen quite a few write-ups on 4th order ratios and what not, but am struggling to find anything on 6th orders. what would a 1:1 compared to a 2:1, 3:1, etc. ratio 6th order sound like? Thanks!
Throw "ratio" out the window. (for the most part)
Go for the ratio that gives you the proper port tunings, port areas, port lengths, and chamber volumes.
Rear tuned low, small port area, smaller volume. Front tuned high, tuned double the rear tuning, large port area, bigger volume.
I say for the most part because I've found that anything below 1.5:1 is in most cases not an optimal enclosure, and the box starts to get very cramped and it gets tough to lay everything out efficiently.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Low tuning, smaller volume @Raptorman? Is that right? Thought low tuning would have a larger volume. Simulations on WinISD seem to favor a large volume for the low side, but i dont have a sickkk low tuned sixth like yourself, either :-P
IG @walledsonic
It's right.
And pay ZERO attention to the graphs in winisd or any other program. They are utterly useless. All you should use winisd for is vent mach and tuning.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Thanks for the confirmation and tip. Ive been toying with a small 6th for my wife's car but havent started building yet.
IG @walledsonic
Its important to differentiate between series-tuned and parallel-tuned 6th order designs.  Series-tuned and parallel-tuned are VERY different beasts.
WinISD only models parallel-tuned boxes and is useless for series-tuned.  With a parallel-tuned box usually the low-tuned side is larger, its the opposite with series-tuned, as Raptorman said.
Builds:
*facepalm*.  Forgot Raptorman's setup was series tuned.  Thanks for chiming in.
IG @walledsonic
For car audio, you will want to work with series. Parallel doesn't fit in very well for us IMO. And series is much easier to get right.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
There have been a couple parallel tuned that I really like
But with that being said I have built 3 different series tuned and they all seem to play just fine. I think that I will stick to 4ths tho. Easier and just as much output in my opinion
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
