WalledSonic Posted November 27, 2017 Author Report Posted November 27, 2017 Put some cushion on the back of the amps to dampen any vibration that may be present. And some neoprene foam on the window frames Well hello subs Connecting amps Nice subs... for now Finally got around to cleaning up the bus bar I made for the ECU/battery under the hood. This was scuffed with a 60 grit orbital sander and has been in the car for a month or so 220 grit orbital 400 grit hand sand Taped off the contact points so I can spray this stuff on it. We'll see how it holds up Mucho shiny. Not sure if I like it, but at least it wont patina under the hood. The bite marks are from me bending this into shape. Gives it character Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Kyblack76 Posted November 27, 2017 Report Posted November 27, 2017 Wicked man. Dig it... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
WalledSonic Posted November 27, 2017 Author Report Posted November 27, 2017 So I get to this point and the bass knob I bought from someone on FB wasnt working on the right side channel. After 5 days of working on this bitch, and you get down to the final step of tuning and you have a bad RCA? UGH. So I took it apart. This one connection looked pretty bad, but wasnt sure if this was the problem or if the problem was in the potentiometer. Checked the bare wire. Nope, wasnt this connection. Bummer. This is a SoundDrive RCA for comparison Well well. Broken lead at the pot At this point, I shouldve known that the burn mark would signify that the pot was likely burnt up. I didnt even think to check the pot, instead, I kept testing at the RCA ends. So I went about pulling the tape off to see how the other connections were. Fucking cold welds/solders And a third. This is NOT a mistake, this is poor workmanship. The solder isnt soaked up well into the wire. Spent the time to reconnect the leads to the pot Then reconnected the RCA cable to the connector But then after testing realized that the pot was actually bad. What a waste of time. Still need to contact the guy on FB. However, I wont be buying anything from him again. Anyway, I'll make my own bass knob at a later date with the parts from this one. Went to Ace Hardware for this adapter FIN Damn, this bitch plays. Im on that half ohm life now Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
YukonXL04 Posted November 27, 2017 Report Posted November 27, 2017 Hell yea! Congrats! Such a great feeling when it comes back to life! 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
Wishuponasub Posted November 27, 2017 Report Posted November 27, 2017 Nice man. Glad to see you get this thing playing. Its been a long time coming. When you start wanting on it let us know how your voltage is with the lithium. PM incoming. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
WalledSonic Posted November 27, 2017 Author Report Posted November 27, 2017 46 minutes ago, Wishuponasub said: Nice man. Glad to see you get this thing playing. Its been a long time coming. When you start wanting on it let us know how your voltage is with the lithium. PM incoming. Voltage is wicked awesome. Ive never been comfortable letting the system play while I step outside the car. I got out yesterday, walked around, listened for rattles, etc. Didnt even drop below 13V at idle (after the PCM cut the alternator off even). The best part is how light the car is. I saved over 150 pounds over the rear axle by switching over, which is a big deal in a car as small as mine. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Kyblack76 Posted November 27, 2017 Report Posted November 27, 2017 Awesome. Vids!?!?!? Meow... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
WalledSonic Posted November 28, 2017 Author Report Posted November 28, 2017 Still need to do some cosmetic shit like put the fender well covers in, finish the relayed fuse block, etc etc. but here's the bank and the wiring. Keep in mind I wanted to be able to pickup someone from the airport with their luggage, so maintaining about half the trunk space was paramount. These coils measure somewhere between 0.3 and 0.4 ohm. Every time I've measured a single sub with coils in parallel, I've never read below 0.8, so I think the coils are closer to 0.4. But I guess I'm living the 1/3 ohm life. 4 hours ago, Kyblack76 said: Awesome. Vids!?!?!? Meow... Couldnt get out til after dark since I was setting my SSF when I got home, but here's a quick vid. Didnt drop below 12.8V at idle. Not bad for 2 5Ks at 1/3 ohm each. I'll get some vids in the daytime soon. This damn early sunset sucks Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ChevyBoy95 Posted November 28, 2017 Report Posted November 28, 2017 for real, shit looks dope. That trunk shot with the LED's is nice Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
hershy314 Posted November 28, 2017 Report Posted November 28, 2017 Nice build, it's really developed over time. Something tells me your not even close to being done yet. http://athphotography.deviantart.com/ http://www.youtube.com/user/hershy314
