2015 Chevy Sonic/Wall/4 15's/10K/Lithium/Large Case Hairpin US Alts
Looking Sick man.  Going to have to get together one day.  and if ya need any help let me know usually free on sundays after church.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Weather was decent this afternoon, so on to welding the alternator bracket!  Its not the prettiest, but it is solid.  This is flux core wire fed, so dont mind a lil spatter here and there.
Scrub scrub
Couple of tacks
I probably ground away too much material, but its still stronger than necessary.  Didnt even warp.
Some more grinding
So here's how I got everything to line up.  You must get the pulleys lined up so you can compare the two alternator mounting bosses.  On the right, you can see my stock alternator with a small slice of wood underneath the pulley as a spacer.  Im holding a ruler from the first groove of one pulley to the first groove of the other.  Notice how flat the ruler is from one end to the other.
Now with the ruler still in place, notice how even the gap is from the bracket on the left side to the stock alt on the right.
IG @walledsonic
Lessons learned on welding yesterday:
1) Zinc plated parts will offgas and create porosity.  Even if you grind away the zinc coating, any small amounts left over near the weld area can create porosity.
2) Be careful with the grinder.  Its easy to remove too much material very fast
IG @walledsonic
HOW TO REMOVE YOUR TRUNK LID TORSION BARS AND INSTALL GAS STRUTS
Remove torsion bars
These brackets were in the way:
Cut em out
Drill the preexisting hole out to the proper hole size to install an M8 riv-nut/press nut
Screw in M8 threaded ball-end
Install one of these on the back wall
Clip strut in place
Here's the other side with light
Showing the setup with a better view
Before I did any of this, I took extra care to measure the closed and open distance that the strut would have to throw by crawling into the trunk and closing it.  6.5" compressed and 10" extended was the most common strut size in this range, so thats what I had to design around.  I could have drilled a new hole in the support to optimize how much the trunk opens, but using the existing hole (from the stock torsion bar) made the task easier.  These are 80 pound struts.
IG @walledsonic
Finally done staining/coating the wall.  Scrubbing the spar urethane in between coats:
Wipe it down
DONE
Gonna have to place the amps just like this to clear all the features of the side of the box (cable bolts, windows, supports, etc)
:peepwall:
So little room to fit these on the sides.  Still gotta figure out the details
IG @walledsonic
Great Stuff (expanding foam) dripped from the ceiling a few months back
Silver and black sharpies
Decent enough!
IG @walledsonic
On 9/19/2017 at 6:40 AM, WalledSonic said:
Not sure man.  Im balls deep in a rebuild right now, so I dont expect it to be playing until late October sometime.  Maybe sooner if the weather would cooperate!  Thanks for checking it out.
As another houstonian, do you frequent texas shows? Dont know if I have ever seen this ride or this build in person. Name?
I wanted to know the same
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
We need to all get together when @DavidClark gets the 15s playing.
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Decent enough!
Ooo  the sharpie experiment! More than descent my friend, Very nice! And that stain is beauty! This shit is coming along nicely. Yeah, if I lived TX, I'd be knocking on your door too lol
