Your kinetiks should rest at 12.8 or higher generally 13.0 - 13.2
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
as for the battery voltage. a little tip i used to use was i had a trickle charger wired onto my battery terminals, and when i would get home for the night i would pull my car into the garage and just plug it in. i never had a problem with starting my vehicle, and the batteries lasted a lot longer. as for your low voltage, i would strongly suggest replacing the front battery, AND the alternator. the stock amperage realy isnt enought to keep up with 3 batteries. believe it or not the alternator not having enough power will slowly fry the batteries. my recomendation is to replace the alternator then the front battery. you should consider the trickle charger trick. just cut the aligator clip ends off and solder some ring terminals onto the ends of the wires. works like a charm :good::good::good::good:
Edited by Bass_Man_2010
This page is crispy_chick3n approved.
© crispy_chick3n inc
i didnt read everything but sometimes making stock alternators charge more than theyre daily capable of can only work for so long.
Ok, a little update here. I started my car up this morning, 14.7, but i didnt slam cuz i was in the neighborhood the whole time. Checked all my connections, everythings tight. Hopefully when i buy the HO alt from cc_audio, i'll keep a higher, steadier voltage.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Wet cell battery should stay at 12.5 and above and your kinetiks should stay above 12.7 volts. Sounds like the batteries are under charged. Get a charger like a Ctek 7002 and charge the front independently from the rear. That charger is fully regulated for all types of car batteries and can fix some of the bad things that can happen from being under charged.
Ok so im still having voltage issues. sometimes i'll be at 14.5, sometimes i'll be at 12.5. its all random, full tilt or not. could i have a dead cell in one of my battery's? stock up front, 2 kinetil's in the back.
under construction
u hate c-fizzy?
nope. no word on it being shipped out yet.
under construction
u hate c-fizzy?
pull them and have them load checked to see if you have a dead cell
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
  • Who's Online   0 Members, 0 Anonymous, 3082 Guests (See full list)
