def not battery.
Pull the fuel line off the front of the motor and turn the ignition on to see if the fuel pump pushes fuel up and out of the line. If you have fuel delivery then you are probably looking at the problem being either spark related (sensor down as said before most likely) or possibly the fuel is not being injected into the motor for some reason (spray ether into the intake to test that one after first verifying spark).
alright i'll have to look into it tomorrow
however, say if i have fuel delivery and spark.. what would that mean?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
It may not help but, the company i work for have us using deicer in our fuel tanks for diesel it may work, dont think itll harm your car.
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
If you have spark and fuel then its probably the crank sensor. It relies on small magnets on the crank to tell it when to tell the ignition system when to fire the spark plugs at the correct time. Also your timing chain/belt could have skipped a tooth/broken.
edit
Forgot to say that if you want to get rid of water in your fuel or fuel line with a gas motor you should use Isopropanol or MDR WaterZorb. Diesel conditioners are not the same.
Hammerdown... 1%
if you get fuel. check your coolant temp sensor that goes to the ecu. its responsible for cold start conditions and if its bad she wont fire when its cold..
first test to see if it will fire using a small shot of starting fluid in a vacume port.. if it does and your getting fuel its more than likely that its the coolant temp sensor.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
however i know it is a fuel issue, i checked for spark.. got spark i sprayed ether down into the engine when i had to spark plug out, put the plug back in and tried to turn it over, it was ALMOST there to fully turning over.. so then i went to my gas valve and pushed on it.. it trickled a little bit and then stopped... no longer puts out gasolene... so im not getting gas to the engine im thinking
Team Sundown Audio
how old is your fuel filter? start with that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
x2 on what N8 said
Team MaxRetribution
Si Vis Pacem Parabellum
It's pry your fuel pump then. Disconnect your fuel line at the filter and turn the ignition one click to see if the pump flows fuel out of the line and if it does then your filter is pry clogged. Disconnect it before the filter of course.
"i'd rather die like a man than live like a coward" quoted from Tupac
This is why i get premium gas not only is there less water in it you get better gas mpg (not much but maybe 1-3 mgp better) also when it gets cold heat is a great thing to add to avoid it as well. 7081294_hee_28202_pri_detl.jpg
1 bottle of heat will treat your whole tank of gas.
also maybe your car is ready for a tuneup as well fuel filter, plugs, air filter, oil change
better mileage out of a higher grade of gas is a very debated topic.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
