HDC3 & HDC4 Optimum Enclosure Size
I posted this on another site, seen this question asked alot, and I get alot of PMs about it here is what I tell everyone.
Here is my input on what I have found to be optimum in sound and overall performance (SPL) for both the HDC3 and HDC4. Now there are several versions of both of these subs and I have tested countless hours with both. This is my recommendation, it isn't intended to be the end all BEST but will get you really damn close smile.png
All recommendations are with alum coil D1 subs. Single sub setup, simply multiply for multi sub setups, works great in my testing.
HDC3 old version (Old Style basket) Stiff suspension
1k input power
HDC310 - 2.0 cube net with 18 sq inch port area per cube - tune between 36-41 hz
HDC312 - 3.0 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC315 - 5.0 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC318 - 6.5 cube net with 18 sq inch port area per cube - tune between 33-38 hz
2k input power
HDC310 - 1.5 cube net with 17 sq inch port area per cube - tune between 36-41 hz
HDC312 - 2.5 cube net with 17 sq inch port area per cube - tune between 34-39 hz
HDC315 - 4.0 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC318 - 5.5 cube net with 17 sq inch port area per cube - tune between 33-38 hz
HDC3 current version
1k input power
2k input power
HDC310 - 1.25 cube net with 16 sq inch port area per cube - tune between 36-41 hz
HDC312 - 2.25 cube net with 16 sq inch port area per cube - tune between 34-39 hz
HDC315 - 3.75 cube net with 16 sq inch port area per cube - tune between 35-40 hz
HDC318 - 5.25 cube net with 16 sq inch port area per cube - tune between 33-38 hz
HDC4 old version (soft suspension)
2k input power
HDC412 - 2.75 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC415 - 4.5 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC418 - 6.0 cube net with 18 sq inch port area per cube - tune between 33-38 hz
4k input power
HDC412 - 2.25 cube net with 17 sq inch port area per cube - tune between 34-39 hz
HDC415 - 3.5 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC418 - 5.25 cube net with 17 sq inch port area per cube - tune between 33-38 hz
HDC4 current version (stiff suspension)
2k input power
HDC412 - 3.0 cube net with 18 sq inch port area per cube - tune between 34-39 hz
HDC415 - 5.0 cube net with 18 sq inch port area per cube - tune between 35-40 hz
HDC418 - 6.5 cube net with 18 sq inch port area per cube - tune between 33-38 hz
4k input power
HDC415 - 3.75 cube net with 17 sq inch port area per cube - tune between 35-40 hz
HDC418 - 5.5 cube net with 17 sq inch port area per cube - tune between 33-38 hz
You will notice the HDC3 and HDC4 like the same tuning based on power and suspension. I have built multiple boxes with different tuning to test how these really performed and these were from my notes on what they really like to get loud. Hope this is helpful.
My recommendation on Amp match is HDC3 on budget side SQ1200, loud side SQ2200, HDC4 budget side SQ2200, loud side SQ3500.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
givin away all the loud secrets :P lol
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Truly grateful for your wisdom man. It's nice of you to help like this. =)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I took the specs off of soundqubes site. I just went with the biggest box they had spec'd for two 12's. It s right at 5 cubes after displacement and tuned to 36.5 hz and running off their 2200 amp. Looks like I am right on with the box size and tuning.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Hey Andrew, while you are at it could you go ahead and test every other sub on the market and give recommendations for those as well? LOL. But really man, thanks for sharing! I can't see an AQ/SQ sub without thinking Black Nasty!
  • 1 month later...
Some-things-are-too-good-to-be-looked-at
Evo X build log
This is awesome! I am about to order a hdc4 18 and strap some bc2000's to it. such great help!
I hate to ask for more since you've already spent all that time and resources, but do you have anything about 4th orders concerning the subs?
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
  • Who's Online   0 Members, 0 Anonymous, 1643 Guests (See full list)
