DC Sound Lab
why not save space an use aero's
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Nice.. Do d1.4s.. Wire that amp down and break a 50
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Not enough baffle space.
Could you pull off the airspace for a 4th order? That would be something that you haven't tried yet and has the potential to get nasty.
Not quite enough room, I would have nowhere to put batteries. I need a quote CJ. Been trying to get Rusty all day.
Thats the plan. I don't know about 50 in this car, maybe 47-48. It does not meter well, but its a low-end demo beast.
SMD Super Seller
My Feedback Thread
You're box designs look like mine, except not in crayon LOL
I'd like to see it with a MPH built stroker with 61mm twins personally, but 2 M2 XL's will suffice I suppose. :drink40:
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Doing the 2 XL 12's. Probably after the Perris show. Here is the box design. Little less port than I would like, but I had no choice with the available width. Still 15.7 per.
that is pretty much my design. Sounds nice but I am thinking about switching it up to aero so i can put my spare back in the trunk by making the box not as deep. I am only running a saz4500 at 2ohms for now. Waiting until the xs group buy to pick up a couple xp3000s. Will drop it down to .5 once I get those batts.
Have you thought about reconing the lvl 6 12 into a 15, and trying it in a nice ported box?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
15 will not work in this trunk
even 12s are a stretch
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
