HHR Ed Posted May 21, 2012 Report Posted May 21, 2012 Just painting resin on does not add any strength. The best way to strengthen boxes is to add layers of wood because it is a rigid reinforcement. And add bracing as to make it even more rigid. If you plan on using fiberglass to add strength, you must use mat and resin in either many thick layers, or in odd, curved shapes. To see what I mean, you can lay a thin layer of just resin down and let it cure. Then see how strong it is on its own. SPOILER: It won't be very strong at all. It can flex and crack easily. Then lay 1 or 2 layers of mat and resin and let it cure. Then pick up the hardened mat and bend it. It will bend quite easily. Much more easily than a layer of wood. Now cover a baseball bat in tin foil and lay 2 layers of mat on it and resin it. Let it cure and then peel it off the bat. Now try and bend it. It will be much tougher to bend. Now try this trick. pour resin into a bucket. make that 4 parts resin. Then add 1 part sand. Then 1-2 parts portland cement. Then add 1 part chop strand fiberglass strands. Now pour it into a tray as to make a thin sheet maybe just a few mil thick. Let it cure and peel it off the tray. Now you will have something almost indestructable you aren't bending 3 layers of 29oz mat. Maybe that 3/4 oz mat some people use but not the stuff i use. 1 Layer might bend but not 3 You are right though, the shape will also make it stronger. I also like the way you think with that brew of sand, concrete, resin and fiberglass Now that sounds strong, and permanent LOL Yeah I use the thick stuff sometimes. It can bend easier once you soak it with resin. But most of the time I have to score it or use multiple pieces in corners and whatnot. And that mixture is the secret material used in 180+ extreme vehicles so keep it hush hush. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
detroitdb Posted May 21, 2012 Report Posted May 21, 2012 cant the bracers brace and the glassers glass..... https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U 2013 DODGE CHALLENGER R/T SUNDOWN ZV4-18 CRESCENDO 3.5K PIONEER AVIC 5300 NEX ALPINE TYPE R 6.5S & 6X9'S ROCKFORD FOSGATE 1.5" TWEETS 5 C&D TECH BATTS
sprkn_ranger Posted May 21, 2012 Report Posted May 21, 2012 I predict hhr Ed's special blend is gonna be added to that "the Internet thinks your system is cool" list once people start using it in their 1500w builds sound pretty damn strong though! Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
S15_Silvia Posted May 21, 2012 Report Posted May 21, 2012 To answer the OPs question: try hooking up stronger and stronger amps directly to the box and record when you have ignition. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
ALPINE408 Posted May 21, 2012 Report Posted May 21, 2012 lets see if it becomes a new fad then i will add it lol Have you ever had your woofers blown?
Namosh Posted May 21, 2012 Report Posted May 21, 2012 Just painting resin on does not add any strength. The best way to strengthen boxes is to add layers of wood because it is a rigid reinforcement. And add bracing as to make it even more rigid. If you plan on using fiberglass to add strength, you must use mat and resin in either many thick layers, or in odd, curved shapes. To see what I mean, you can lay a thin layer of just resin down and let it cure. Then see how strong it is on its own. SPOILER: It won't be very strong at all. It can flex and crack easily. Then lay 1 or 2 layers of mat and resin and let it cure. Then pick up the hardened mat and bend it. It will bend quite easily. Much more easily than a layer of wood. Now cover a baseball bat in tin foil and lay 2 layers of mat on it and resin it. Let it cure and then peel it off the bat. Now try and bend it. It will be much tougher to bend. Now try this trick. pour resin into a bucket. make that 4 parts resin. Then add 1 part sand. Then 1-2 parts portland cement. Then add 1 part chop strand fiberglass strands. Now pour it into a tray as to make a thin sheet maybe just a few mil thick. Let it cure and peel it off the tray. Now you will have something almost indestructable Got damn, Ed! You really like to pile on the homework! My Ram Quad Cab Blow-through
SPL KID Posted May 22, 2012 Report Posted May 22, 2012 To try and shed some light on the glassing of the box (interior) is mainly to help reduce turbulance and increase the flow of air. . For the interior of the box is a day long or so process to do it properly an to be effective. Sand and remove all glue drips vacuum and blow out all the dust particles you can. Make small resin batches pour into each standing side of the enclosure so it pools maybe 1/4 inch so it resembles a small 45 angle repeat for each box corner( you will have to pro up the enclosure for this.) Will take several small batches and after your last corner is dry and solid make one last batch to brush over the entire interior on the enclosure you should do this at least twice (poke all air bubbles). Once that is cured and dried get a fine grit of sandpaper and electric palm sander and smooth out any suspect areas. Now you have a air tight free flowing enclosure that will take anything you trhow at it without question. If your using multiple woofers a wooden Dowel rod between each woofer will help control flexing. 2x4 and similar bracing just obstructs air flow and can take away from plotted Cu ft by adding displacement. NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
skittlesRgood Posted May 22, 2012 Report Posted May 22, 2012 Screw bracing, resin, and all that nonsense. Be like me and just use particle board & deck screws. I don't even use Gorilla Glue glue anything like that. Just cut the wood and then screw them together. You fancy huh? I use cardboard and hot-glue ive seen that done lol. with one coil hooked up. cant the bracers brace and the glassers glass..... because everyone insists that their way is THE way. even when they are wrong. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
