98GCLimited Posted June 19, 2012 Report Posted June 19, 2012 Play it normal, turn it down if you start to smell coil though This. Get the sub moving, if it starts to stink turn it down for a bit and back up. Once the suspension is loose enough to allow the sub to move enough to keep the coil cool it shouldnt get stinky anymore and you can just slam on it without having to turn it down.
Smurfboy Posted June 19, 2012 Report Posted June 19, 2012 Play it normal, turn it down if you start to smell coil though This. Get the sub moving, if it starts to stink turn it down for a bit and back up. Once the suspension is loose enough to allow the sub to move enough to keep the coil cool it shouldnt get stinky anymore and you can just slam on it without having to turn it down. Everytime I hear someone says "I smell something", it always makes me think that the "gain" setting is not properly on their amp(s). There are many factors to consider about when it comes to "smell something" and not just from 'crankin' the volume up.
ChevyBoy95 Posted June 19, 2012 Report Posted June 19, 2012 Play it normal, turn it down if you start to smell coil though This. Get the sub moving, if it starts to stink turn it down for a bit and back up. Once the suspension is loose enough to allow the sub to move enough to keep the coil cool it shouldnt get stinky anymore and you can just slam on it without having to turn it down. Everytime I hear someone says "I smell something", it always makes me think that the "gain" setting is not properly on their amp(s). There are many factors to consider about when it comes to "smell something" and not just from 'crankin' the volume up. bad thing about judging for smell, if you havent reconed a lot, newly reconed subs smell when they start to move a lot, smell of the glues and whatnot, rather than a smell from the coil heating up. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
SnowDrifter Posted June 19, 2012 Report Posted June 19, 2012 ^^ But that is a sweeter smell vs. a burning acrid smell ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Chris Davis Posted June 19, 2012 Report Posted June 19, 2012 Ya should only take 24 hours for the glue to settle you said you should be receiving yours are they being shipped or you picking them up if there shipped you should be fine to fire them when you get them back seeing how its pretty much given its in transit more then 24.
ChevyBoy95 Posted June 20, 2012 Report Posted June 20, 2012 ^^ But that is a sweeter smell vs. a burning acrid smell if someone doesnt do recones a lot, they probably couldnt tell the difference. that is what i was getting at. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
getlocivic Posted June 20, 2012 Report Posted June 20, 2012 i ALWAYS do break in minimum of 2hrs free air on a 20hz tone..using my home theatre amp.. subs with stiffer suspension i play it longer everybody has thier own method..
Chris Davis Posted June 20, 2012 Report Posted June 20, 2012 i ALWAYS do break in minimum of 2hrs free air on a 20hz tone..using my home theatre amp.. subs with stiffer suspension i play it longer everybody has thier own method.. True that each has there own tricks or methods I like that with the home amp.
MrSkippyJ Posted June 20, 2012 Report Posted June 20, 2012 What exactly do people who break their subs in hope to accomplish? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
sprkn_ranger Posted June 20, 2012 Report Posted June 20, 2012 What exactly do people who break their subs in hope to accomplish? I wonder this too. Unless the sub manufacturer says to go easy on the sub for a few hours, then it is good to go full tilt out of the box. That is assuming your amp is tuned right and the enclosure is properly suited for the sub. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
