Very disappointed
Iirc from you build log, you don't have any roundovers or anything in your ports? Fixing this should help alittle.
And maybe more port as mentioned earlier.
Rink is 100% sealed off as I have found no leaks. And how would I take the middle piece out? It's glued nailed and screwed in?
Rebuild.
^^x2....
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
rebuild with a singhle chamber box port on the driver side.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If I seal off the port. And do a sweep can that tell me my resonant freq or do I have to build a new sealed box to specs
