Stopping my back hatch from moving?
in a practical way? probably not....weld it shut or weld some very heavy steel to the inside (so it'd still open, but itd be heavy as hell) that's just my .02 i guess
Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586
i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
6/18/82 - 4/17/12
R.I.P. to my sister Shana
weld it shut
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Good luck. The only real thing I've been told that will help is to run all thread from the hatch to the floor and use a tensioner in the middle to tighten down. But that's not practical for daily use. You have no idea how bad a hatch can actually flex
Yup good luck with that my team mate joey did that threaded rod with turn buckle type lock downs but even with those tighted as much as he could at 28 hz would still flex like crazy and you can't open your hatch unless you take the turn buckels off from the inside yes it helped a lot but it was a pain in the ass when you wanted to open the back plus it still flexed
stop posting useless solutions please.
What I have done so far
  • Lowered the metal piece that holds the rear latch. (unscrew the two bolts and pushed it down)
  • Damplified the whole trunk as much as I could inside the hatch and on the outer panels.
  • Great Stuffed The WHOLE hatch except where the wires were
  • FIberglassed the hatch panels to add weight and strength
Does work WAY better but air still escapes.
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
the hatch on my wagon has the inner and outer skins deadened fairly heavily.... when that didn't help enough, I added a 9mm thick MDF panel under the trim panel, screwed with about 60 screws, plus silicone sealant...
didn't help a whole lot....
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
