chassis ground sparks when i connect it..
should see the spark get if i touch the leads on my rack too. it may be only 12 volt but its wrench melting , ask me how i know.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You said you can still use the car so you left the stock wires in place?
If so then you electrical is grounded to the chassis already.
Use a voltmeter and measure the voltage of this wire you're trying to ground with respect to the battery negative terminal (black wire on the battery neg terminal, red wire on the wire you're trying to use).
If its shows ~0v then its correct. If its ~12V then you're grounding out a positive wire which is bad.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
You don't say? LOL :D
I'm gonna hate
Lol I got a zap from -48 volts at work. The bank was floating around -56 to -57 didn't feel very good.
i also found I can drop a wrench quick too. Its fun getting it off the terminal thoguh.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I get a small spark. It's enough to make the terminal "stick" to the battery for a second. But not enough to cause noticeable heat. If your wires are getting hot and melting you have a short somewhere. You need to go and trace every one of your wires to make sure they are attached where they should be and that no insulation has rubbed through anywhere
Lol I am an electrician in the coast guard. I had a high voltage 400hz (yes I said hertz not volts lol) power supply (working on a helicopter start rectifier) arc right in my face... the dumb bitch I was working with said she has secured power, so when I hit all the terminals with a shorting probe before I stuck my hands in there (lots of caps in there) it instantly blew the tip off the probe, and melted the teeth off the clamp on the other end. Brightest light I have ever seen... turns out she had not secured the power, so instead of just discharging the caps (would have been a small spark if anything), I grounded out the 400hz side of the power supply lol. Almost punched a girl that day.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
Lol I've done that with 16 volt batts resting at 17.4 volts let just say that wrench is half the size it use to be lol
Wire melting is a short plain and simple
I would be worried if you didn't get a little spark
I get a spark with my sundown amp and I did with my audiopoop amp lol
It's normal to get a spark, but if you're melting wire and plastic in the process I would think that you either need to upgrade your wire, or somehow you are directly grounding your power wire :shrug:
  • Who's Online   0 Members, 0 Anonymous, 978 Guests (See full list)
