JohnnyGunz Posted June 7, 2013 Author Report Share Posted June 7, 2013 Check your fuses or even bypass it to see if there is something wrong with it as a test. some time fuses pop without physical breaking it might be intact slighty. try replaces that fuse on your main power run to the back and what size is it ? do you have a 4 channnel amp ? it happen to my friend... the fuse was not broken completely killing his amp pull.. he replaced it and was fine Haven't checked the fuse yet, good idea. May want to make sure your alternator is actually doing what its suppose to and that your yellow top is still good. You shouldn't be having those problems with a 240amp alt on a 1500w amp unless you got it wired to something stupid low I'm gonna bring it to my boys house later today or tomorrow and see what its cranking out. Both the yellow top and alternator were purchased within the past 2-4 months How is this a Skar issue? Because I was wondering if anybody else has had similar issues with either the SK1500.1 or the VVX10s Link to comment Share on other sites More sharing options...
JohnnyGunz Posted June 7, 2013 Author Report Share Posted June 7, 2013 How is this a Skar issue? Also, I've been through numerous amps/subs and never had an issue until I put in Skar Audio subs/amp. Link to comment Share on other sites More sharing options...
Agreene Posted June 7, 2013 Report Share Posted June 7, 2013 i myself have a skar 1500.1 there super efficient they draw little amperage then other 1500 watt amps, something is obviously wrong as stated. just putting it there that the 1500 doesnt take to much power. but yea check your fuse also give us some voltage readings. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 7, 2013 Report Share Posted June 7, 2013 i myself have a skar 1500.1 there super efficient they draw little amperage then other 1500 watt ampsYou know you just totally contradicted yourself right?An amp drawing more current then other 1500 watt amps being super efficient is nothing to brag about by any means. LOL I think he is trying to say they less amperage than other 1500 watt amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 7, 2013 Report Share Posted June 7, 2013 what are the subs wired to (final ohm load) Team Flex Issues Link to comment Share on other sites More sharing options...
White Lightning Posted June 7, 2013 Report Share Posted June 7, 2013 A high output alternator is absolutely useless without something to charge ... Step one in a system is adequate power and electrical ... No need to trouble shoot anything until you get a second battery in that system so the alternator will operate properly ... My dad told me LONG ago ... You GOT to know what you are doing because you HAVE to Pay if you want to play the game !!! Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
TaylorFade Posted June 7, 2013 Report Share Posted June 7, 2013 You say you're having voltage drop... what's your voltage dropping to? What's it charging at? How do you know the subs are clipping from "lack of power?" Link to comment Share on other sites More sharing options...
TylerParrish Posted June 7, 2013 Report Share Posted June 7, 2013 Would also like to know final ohm load What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted June 7, 2013 Report Share Posted June 7, 2013 Final ohm load, extra battery or batteries and a volt meter would be helpful in this situation. Along with a DD1. Any fine adjustment with clipping helps voltage drop. My voltage drop at full tilt went up by .2 yesterday because I tuned with a -7.5db tone instead of -10... No real difference by ear, maybe even better then it was on -10.. And my voltage stays higher. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted June 7, 2013 Report Share Posted June 7, 2013 low power doesnt cause subwoofers to clip, clipping is from a clipped wave... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
