Problems with Skar Audio 1500.1 + 2 VVX10s
Check your fuses or even bypass it to see if there is something wrong with it as a test.
some time fuses pop without physical breaking it might be intact slighty. try replaces that fuse on your main power run to the back and what size is it ? do you have a 4 channnel amp ?
it happen to my friend... the fuse was not broken completely killing his amp pull.. he replaced it and was fine
Haven't checked the fuse yet, good idea.
May want to make sure your alternator is actually doing what its suppose to and that your yellow top is still good. You shouldn't be having those problems with a 240amp alt on a 1500w amp unless you got it wired to something stupid low
I'm gonna bring it to my boys house later today or tomorrow and see what its cranking out. Both the yellow top and alternator were purchased within the past 2-4 months
How is this a Skar issue?
Because I was wondering if anybody else has had similar issues with either the SK1500.1 or the VVX10s
i myself have a skar 1500.1 there super efficient they draw little amperage then other 1500 watt amps, something is obviously wrong as stated. just putting it there that the 1500 doesnt take to much power. but yea check your fuse
also give us some voltage readings.
You know you just totally contradicted yourself right?
An amp drawing more current then other 1500 watt amps being super efficient is nothing to brag about by any means. LOL
I think he is trying to say they less amperage than other 1500 watt amps.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
A high output alternator is absolutely useless without something to charge ... Step one in a system is adequate power and electrical ...
No need to trouble shoot anything until you get a second battery in that system so the alternator will operate properly ...
My dad told me LONG ago ...
You GOT to know what you are doing because you HAVE to Pay if you want to play the game !!!
Would also like to know final ohm load
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Final ohm load, extra battery or batteries and a volt meter would be helpful in this situation. Along with a DD1. Any fine adjustment with clipping helps voltage drop. My voltage drop at full tilt went up by .2 yesterday because I tuned with a -7.5db tone instead of -10... No real difference by ear, maybe even better then it was on -10.. And my voltage stays higher.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
low power doesnt cause subwoofers to clip, clipping is from a clipped wave...
  • Who's Online   0 Members, 0 Anonymous, 345 Guests (See full list)
