Why people not like strapping amps?
Karkov
Maybe it will help you guys to understand by thinking about it as strapping being running your amps "in series" while gain matching is more or less running "in parallel."
When strapped, you have the same amount of current total running through your circuit (both amps and subs) as you would gain matched running in each amp. You get the extra power because when you strap them together your output voltage potential doubles.
Gain matched, you have both amps each outputting at their current capacity but each only has half of the voltage output as the strapped unit. So in this case you are actually putting twice the current into your load (subs) as if you were strapped. Same power yes but that power is made differently.
So yes, the amps see the same load, work just as hard, and the amps have the same amount of current going through them in either configuration. The difference is in what kind of power you are giving to your subs.
Hope that helps?
you don't gain extra power by running strapped.
Follow my Tweet (Twitter)
Hope that helps?
thank you!
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
I always thought it was just for ease of use to strap instead of gain matching the slave amps if you ran them separately. That was how I always took strapping to mind. Like you set the xover, gain, etc. on the master amp and whatever settings those are get cloned to the slave amp that it is strapped to. I strapped my previous sub amps at .5 ohms so each amp was getting .25 and i smoked one of them but I can't really say I didn't expect it. Other than that it was the exact same sound and response if I left them separate with the gains matched than if I left it strapped. I just found it a little easier to wire up and run the amp strapped than separate.
:No:
most amps have master and slave for these functions.. not master and slave for strapping but master and slave for control purposes.. why am i still in this facking thread.. :unknw:
:ninja:
I think people are stuck on what the amp sees for load and not the sub.
D4 sub wired to 2ohm on strapped amps your sub will still see 2ohm and the amps will see 1ohm each.
I dont think anyone is saying you gain power..they are saying its delivered a different way. 250volts x 10amps is 2500watts...or 125v x 20amps is 2500...one is higher voltage one is higher current.
If their statements are true or not...I have no idea but No one is saying you gain power...just delivered differently.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
You're right sensai, sorry, I forgot about RF amps that have that. :peepwall:
You can't just say that agan I have amps right now that strap in parralle that double the ohm load so if you strap at 2 ohms the amps see 4 ohms its not allways lower
I knew this would get over some people's heads, fritos gets it. Maybe I should do a video to help better explain.
Think of it like this would rather have an amp doing 5k at 2 ohms or 2 2500 at 1ohm each it comes down to the components that makes up that power, ACV and ACC.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
This thread just made me wanna stay in the little leagues.................. :trippy::wacko: .
95 Civic 4 door-
2005 Chevy SilveradoSkar 15' IVX (2)Skar SK 800.1DSkar SK 85.4 A/B - Yet to be installed
2-Deep cycle Marine Batteries
Big 3
A whole shit load of 1/0 welding cable. Lil overkill for what I have but I have it so Im using it!
  • Who's Online   1 Member, 0 Anonymous, 1175 Guests (See full list)
