cjvue Posted August 16, 2013 Report Posted August 16, 2013 LDF MDF HDF.... I'm done with all them dust. My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
audiofanaticz Posted August 16, 2013 Report Posted August 16, 2013 Sorry you didnt like my reply. But the wood your using is not something great, or even better then mdf. It dont matter if your using maple, birch, cherry, or whatever your minimum wage big box store employee says is close to the wood you use to get. They all have 1 thing in common, cheap plywood cores usually fir or poplar. As another user said, this birch dont trash your saw blades like mdf, well thats because this wood is weaker then mdf, filled with various sized voids. Or its so much lighter then mdf, but again ply wood is not heavy... 13ply birch, quality birch, trashes my blades fairly well, I notice the wood is there unlike mdf, and im sliding it thru a 3hp tablesaw with a $60 blade. Cutting some cheap plywood birch up, its like butter and mdf still has more resistance going through the blade. Ive used cheap birch enough and hate using it. I also find it funny how this wood is so much stronger but yet when i load and unload it, i see the wood bending from the ends not being supported worse then mdf, but its stronger right! Walk down your big box store, look at their "fine woods" and look at the cores, forget about that thin veneer of cherry, maple, birch that your paying double the price for vs the plywood.. You will see for yoursellf that its just plywood As cstrokerv said, the $75 a sheet birch from menards is GREAT stuff, its pricey but for a good B/C wood its worth it , but again as others havve said, check local cabinet shops they use a higher end wood that cant normally be found in big box stores, and they will usually selll it cheaper without a huge markup. But be aware a quallity birch is going to weight 80+ pounds. MDF weights from 70-90 pounds depending on the vender. http://www.menards.com/main/building-materials/panel-products/specialty-panels/hardwood-plywood/3-4-x-4-x-8-baltic-birch-plywood/p-1479674-c-13334.htm And if you want quality lightweight mdf, then buy TruPan but be ready to spend some money if you find a retailer that carries it.
AMI CUSTOMS Posted August 16, 2013 Report Posted August 16, 2013 I just use MDF, half the price, birch here is around $80 for the one sheet of baltic I got, which is what the top of my wall is made of, 13 ply, it is some good wood, but I could get two sheets of MDF for that and be WAY stronger, but heavier too lol. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
audiofanaticz Posted August 16, 2013 Report Posted August 16, 2013 I love my mdf too, you can just manipulate it in such devious ways
tacomaguy1 Posted August 16, 2013 Report Posted August 16, 2013 I laugh when I see people putting in a wall and say they are worried about the weight That's the last thing I was worried about when I did mine lol MDF crew checking in Team Flex Issues
twisted1 Posted August 28, 2013 Report Posted August 28, 2013 I haz mdf.... yep its heavy. Shit prob flexes to but I couldnt find birch 09 mustang gt
CJ18 Posted August 28, 2013 Report Posted August 28, 2013 The only thing is hate about MDF is the damn dust. If it would cut cleaner I would have no issues with it at all.
Tribe Called Bass Posted August 28, 2013 Report Posted August 28, 2013 The only thing is hate about MDF is the damn dust. If it would cut cleaner I would have no issues with it at all. The dust....my basement went from being grey to being completely brown.
OrionStang Posted August 29, 2013 Report Posted August 29, 2013 13-ply Baltic Birch, 5x5 sheets for $37 down here. Hanks Hardware FTW. Hell, I probably got enough big pieces wasting away on my back porch to build a pretty nice box or two. SMD Super Seller My Feedback Thread
corona_jeff Posted August 29, 2013 Report Posted August 29, 2013 Only advantage I see with mdf is when adding resin. Now when someone posts resin doesn't add strength, I call bs when mdf soaks half way thru and birch only soaks up 1 layer.
