Voicecoil terminal cannot fit 2 wires! Need help ASAP!
Golitan11
Myles advice is the best you have got so far op. taking copper out of your wire reduces conductivity so you might as well use smaller wire if you go that way. Don't be lazy, do it the right way like Kyle showed you.
I disagree with you on that.
Since when do you use thinner wire because you can't fit all the strands in? That's like saying "Oh my ground lug isn't as thick as my 0 gauge. Might as well use 8 gauge then"
And in all honesty trimming off a few strands so you can fit more of the wire in the lug will actually help rather than hurt. More contact area. A couple strands off the end doesn't negate the conductivity of the entire wire.
I'm using knu 8ga for my subs. Had to trim it down a bit to fit
same thing here. I also use 4 separate 8awg wires twisted together for the power and ground on my sub amp. Both that and my sub needed a tad snipped off and it's fine
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
hell if its that huge of an issue, solder then then clip it to the size you can fit.
I've done this in the past with good results too.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Going to put this out there. I DO NOT THINK I'M A KNOW IT ALL PERIOD. FLAME ON SOMEONE ELSE. AND THANK YOU FOR THE ONES WHO UNDERSTOOD WHAT I WAS SAYing. All I was doing was trying to help Lolz.
Give each coil it's own wiring and wire them to some bolts on the box
Thats how mine are done, 4ga from the amps to the wall, 8ga from the wall to the subs
Used to have a loud truck
Suddenly, a wild butthurt appeared out of nowhere
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
