set gain with bass knob all the way up.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I hope you're joking
not joking, bass knob is just a remote gain not a boost. set the amp gain with the remote turned up will prevent you from clipping with the knob.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
not all remotes are like that.
my old amp had a remote that simply boosted a certain freq. so I put a knob in line with the RCA's which I then made sure was on full before DD1ing
OP. If it boosts a freq... take it out. go spend the little amount of money to get a lc1 ( I think thats what its called over there, the RCA inline knob)
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
This. I'll bet that OP set amp gain with knob all the way down now wondering why just a little touch makes it have all types of that extra bass.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Yes it's
An audio control, and yes I set it with it down and it's not a bass knob that acts ass a bass boost just as a level control, so I should reset it with it all the way up?
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
Hu powered speakers and 8 12's walled? Now I've seen it all. :roflmao::suicide-santa:
Yes, you usually set it with the remote all the way up unless it's a bass boost.
And lose the line driver, offcourse your gain will be at max if your amp can only handle 6V instead of the maximum 8 a line driver can provide at maximum volume.
Line drivers are useless in 99% of the installs that use them, only use for them is if you split a lot of RCA's, to like 8 or more amps and you start out with a 1V signal or lower, other then that it's pointless.
If it removed engine noise for you that's very lucky for you because they always add noise to the signal, just find the origin of the noise and lose the line driver.
Edited by kirill007
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
