lower notes clip easier?
ChevyBoy95
When you did this, you were setting at max volume right? Do this: do the same test again, but do it at half volume, so that electrical supply isn't a factor. Bet you get different results :)
probably box rise.
He said it was unloaded.
Impedance varies even while subs are not loaded, so it could still be an issue even if you take what the box does to impedance out of the equation.
what i mean, there is nothing wired to the output of the amp except the oscope....
I'm waiting for an answer.
where is Tony?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Is it possible at lower frequencies you are seeing less resistance which is a increase in power causing it to clip? :unknw:
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Bump for info.
Edit: It's been explained in numerous other threads why higher frequencies drop your voltage more. (off topic but discussion in this thread)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Bump for info.
my system is opposite to that. 40+ have no voltage issues, 35 and down im in the low 12s and high 11s.
Bump for info.
oh, sorry, I forgot the reasoning, must have been specific to something or other. I bow out before shit storm. Again, my apologies.
EDIT: On RF's birth sheets they make full power at higher hz, like200'ish and the curve keeps climbing until then, maybe gets added to the equation some how with specific variables but again maybe means nothing, just thinking out loud at this point. =)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
My subs see the least amount of resistance and get the most power around the 50 hz range ( also where I get most voltage drop ) Im actually running some tests soon to confirm the power and independence at each frequency.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
