I've got the Drive In Theater speaker/switch box/ Bass knob part of the build out of the car right now. I done the body work on it, cut it down some and smoothed every thing out on it! It's at the paint shop now getting a fresh coat of White with Blue pearl sprayed on it then it's off to be pinstriped! I'll be sure to post pictures of it once it's done!
Man I'd love to have this ride. Killer system dude. Thumbs up to you. Love this thing. Great job. This car is CLEAN..
Oh this is what car audio means to me. Meaning thinking outside the box as they say. Just Dayummm.
Thanks guy's I tried to keep under the hood clean & simple! I have since this picture add a second 270 amp alternator as well as did a serpentine pulley conversion on it.
Goes with the rest of the car..so clean !
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
This is the future upgrade for the Wagon. 2 Sundown Audio Zv3 15's flush with the floor with curved ports!
This is where all my Air bag set-up is hiding, behind the spare tire compartment is 2 Tanks a 5 gallon & a 3 Gallon stacked together, 2 Viair 480c compressiors & Eight 5/8" Parker Valves! It's all in there kinda tight!!!
This a little off the subject of the Wagon but this a little just for fun project I'm working on right now. Old Military Ammo can boom box! The center is the port for it!
This is a few pictures of the suitcase build that was done on my kitchen table! You can see all the fans that are in it to keep it cool, One of them on the back is pulling air while the other is pushing air then there is 2 cross wind fans as well. The inside was reinforced and painted white as well. Everything on the rear of it is quick connect so I can remove it easy if needed. All the wire inside is Sky High wire and the Fuse/Ground distribution block was custom made for the suitcase by ToolMaker as well as the Quad 1/0 ring terminals. To keep from overloading my remote I added some relays to turn the fan's on as well as the LED's. There is a lot going on inside a small space!!!
so much cool stuff...
dear god man. I could see this as a Feature on Speedhunters...
